> Why do replacement CV joint boots have six holes instead of the four like original
TonyA
post Feb 4 2024, 10:10 AM
Nachmal
Why do replacement CV joint boots have six holes instead of the four like original.
Is it so the grease has a spot to leak out in a few years and splash all over. I am getting pissed at aftermarket stuff not made right and I find this out six months after purchasing. Why are there six holes. In my quest for originality I WANT IT RIGHT (I know most don't give a crap) but I do! My rant for today thanks for watching.
frank_c
post May 11 2026, 11:14 PM
I'm reviving this thread to see if anyone has found a source for CV Joint boots with the 4-bolt flanges, or a better solution for the 6-bolt boots?
I recently replaced both axles/CV joints with the pre-built axles from PMB, and the boots are slinging the grease out. The grease appears to be coming mostly from the empty holes in the boot flange where the roll pins are located.
I do have a pair of the old 4-hole boots that I removed from the old axles that I plan to install on the inner joints so that I can keep an eye on them, but I need to find a solution for the two outer joints.
I was wondering if anyone has tried drilling and tapping the 10mm roll pin holes in the CV Joint for a short 12mm bolt at the boot end of the CV Joint - keeping the roll pin at the other end? This would not only seal the empty boot flange hole, but also form a tighter seal of the boot flange against the CV Joint (and allow the use of 3 retainer plates instead of 2). But, since CV Joints are hardened steel, I did not know if this is something that would require a machinist.
TonyA   Why do replacement CV joint boots have six holes instead of the four like original   Feb 4 2024, 10:10 AM
914Sixer   The 914 boot is the same size as the stock VW Bug ...   Feb 4 2024, 10:26 AM
mate914   Why do replacement CV joint boots have six holes ...   Feb 4 2024, 10:31 AM
TonyA   Why do replacement CV joint boots have six holes...   Feb 4 2024, 12:25 PM
burton73   This is a picture from web. How would a person fix...   Feb 4 2024, 10:47 AM
73-914   A reproduction is by definition not original   Feb 4 2024, 11:48 AM
TonyA   Excuse me I mean original looking.   Feb 4 2024, 12:23 PM
MartyYeoman   Add a little piece of HVAC foil sealing tape to th...   Feb 4 2024, 12:55 PM
fixer34   You got me wondering since it has been a LONG time...   Feb 4 2024, 01:10 PM
914Sixer   Thinking a plastic plug would accomplish closing t...   Feb 4 2024, 01:12 PM
fixer34   Thinking a plastic plug would accomplish closing ...   Feb 4 2024, 04:39 PM
pek771   The diameter of the boot is larger than the CV joi...   Feb 4 2024, 09:14 PM
bkrantz   The diameter of the boot is larger than the CV jo...   Feb 4 2024, 09:26 PM
jim_hoyland   So, what is the best solution when replacing ?   Feb 5 2024, 07:33 AM
pek771   I’m going to put a bead of silicone around the p...   Feb 5 2024, 07:52 AM
DRPHIL914   Why can't someone make a correct design reprod...   Feb 5 2024, 07:54 AM
76-914   These are the woes of owning a 50 year old car in ...   Feb 5 2024, 09:07 AM
MikeK   Pardon my ignorance, but which six holes are you r...   Feb 5 2024, 09:31 AM
DRPHIL914   Pardon my ignorance, but which six holes are you ...   Feb 5 2024, 09:54 AM
VaccaRabite   Because its a Beetle part that EMPI is selling to ...   Feb 5 2024, 11:50 AM
bkrantz   Because its a Beetle part that EMPI is selling to...   Feb 5 2024, 07:43 PM
MikeK   Thanks for the enlightenment. Can the stub axles...   Feb 5 2024, 07:35 PM
Olympic 914   It seems even the new Porsche ones have six holes....   Feb 5 2024, 08:28 PM
pek771   looks like the new cv joints are 90 mm od, and the...   Feb 6 2024, 06:52 PM
frank_c   I'm reviving this thread to see if anyone has ...   May 11 2026, 11:14 PM
DennisV   I'm reviving this thread to see if anyone has...   May 12 2026, 06:31 AM
Shivers   [quote name='frank_c' post='3256797' date='May 11...   May 12 2026, 10:16 AM
914Sixer   Here is your answer. Price is STUPID. Then you a...   May 12 2026, 06:13 AM
brant   HVAC aluminum foil tape has been working fine for ...   May 12 2026, 06:26 AM
IronHillRestorations   I like Marty’s idea of covering the holes from t...   May 12 2026, 08:52 AM
frank_c   Thanks for the responses. I looked at my old 4-b...   May 12 2026, 09:15 AM
Shivers   Dang I have two :)   May 12 2026, 12:28 PM
- Lo-Fi Version Time is now: 12th May 2026 - 02:54 PM
