> Can someone point me to brake rotor and pads, Refreshing my old ass brakes
Fart/4
post May 12 2026, 08:35 PM
Just looking for
Best value or stock braking capability
Where do I buy from and what's a realistic budget ?
For all four corners
Shout out to the cheap sob
Chrome don't get you home
( Glendale speed center ) (IMG:style_emoticons/default/first.gif)
914rrr
post May 15 2026, 09:31 AM
I need some local assistance desperately.
This week I took my wheels / tires off to have them balanced. I figured I may as well check the rear brakes while the wheels are off, since I was hearing some brake grinding noises. I discovered that the rear pads on the drivers side were past shot. I ordered some pads and retainers from O'Reilly's just to bet it back on the road and they would arrive today. Well, they arrived. Evidently multiple superseded part numbers resulted in pads that are the right shape but physically too large. (IMG:style_emoticons/default/mad.gif)
I need at a minimum 1 pair of used pads and 2 retaining spring clips. A set of used or new rear pads, a complete rear brake hardware set and 1 good used rotor would be ideal.
There's a good chance I may be selling my DD Lincoln Navigator today. My 914 is my only other car, hence the urgency. Any local parts above that I could pick up today would be immensely appreciated! Anywhere within 1-2 hours from me would work.
BillC
post May 15 2026, 11:35 AM
QUOTE(914rrr @ May 15 2026, 11:31 AM) *
How far off are those new pads? If not too much, maybe you just need to retract the pistons a little bit more to make room for the pads.
If you get desperate, you can also use a grinder to thin down the pad material a bit. Just be aware that you will end up with an uneven face that will take a while to bed in. Make sure to wear a filter mask if you do this.
Fart/4   Can someone point me to brake rotor and pads   May 12 2026, 08:35 PM
Montreal914   Call Eric Shea at PMB. :) https://pmbperformanc...   May 12 2026, 08:38 PM
930cabman   Call Eric Shea at PMB. :) https://pmbperforman...   May 13 2026, 04:58 AM
914rrr   I'm looking as well. Thing is, I need almost a...   May 13 2026, 06:24 AM
Tom1394racing   I'm looking as well. Thing is, I need almost ...   May 13 2026, 06:30 AM
914rrr   I'm looking as well. Thing is, I need almost...   May 13 2026, 01:29 PM
Dynosoar11   I'm looking as well. Thing is, I need almost ...   May 13 2026, 04:09 PM
914rrr   I'm looking as well. Thing is, I need almost...   May 13 2026, 04:39 PM
914rrr   I need some local assistance desperately. This w...   May 15 2026, 09:31 AM
BillC   I need some local assistance desperately. This ...   May 15 2026, 11:35 AM
914rrr   Calling "old timers", I'm now befudd...   May 15 2026, 07:15 PM
914rrr   A pic of my rear caliper.   May 15 2026, 08:08 PM
Ninja   Those top pads look weird! If the left side a...   May 15 2026, 08:17 PM
914rrr   Those top pads look weird! If the left side ...   May 16 2026, 12:11 AM
914rrr   I think I've cracked the code using Rockauto a...   May 16 2026, 12:51 AM
914rrr   Another part # for 914 rear brakes on AutoNation f...   May 16 2026, 09:00 AM
914rrr   Here's an update. Received the pads and hardwa...   May 24 2026, 08:00 PM
Literati914   Here's an update. Received the pads and hardw...   May 25 2026, 10:03 AM
Literati914   Just a note, these are the ones I used at the rear...   May 25 2026, 10:09 AM
914rrr   Sorry, duplicate post   Jul 24 2026, 07:04 AM
914rrr   Tech question regarding 914 caliper piston boot cl...   Jul 24 2026, 08:37 AM
- Lo-Fi Version Time is now: 24th July 2026 - 10:57 AM
