| Fart/4 |
May 12 2026, 08:35 PM
Newbie ![]() Group: Members Posts: 9 Joined: 13-February 25 From: California Member No.: 28,619 Region Association: Central California |
Just looking for
Best value or stock braking capability Where do I buy from and what's a realistic budget ? For all four corners Shout out to the cheap sob & Chrome don't get you home ( Glendale speed center ) (IMG:style_emoticons/default/first.gif) Attached thumbnail(s) |
| Ninja |
May 15 2026, 08:17 PM
Member ![]() ![]() Group: Members Posts: 251 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Those top pads look weird!
If the left side are still decent you might have a caliper issue. The square cut O-rings lose their ability to retract the pistons when they get old. When new/good they slightly retract the piston when fluid pressure is released. It's not much, .002"-.003" but if they are rock hard, they leave the pads solidly against the rotor causing excessive wear/brake dragging. It's a bit like "riding the brakes". Front calipers are easy to rebuild, rears are NOT! The biggest issue with my 75 when I purchased it was one of the rear calipers did exactly this and trashed both the pads and the rotor. |
| 914rrr |
May 16 2026, 12:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
Those top pads look weird! If the left side are still decent you might have a caliper issue. The square cut O-rings lose their ability to retract the pistons when they get old. When new/good they slightly retract the piston when fluid pressure is released. It's not much, .002"-.003" but if they are rock hard, they leave the pads solidly against the rotor causing excessive wear/brake dragging. It's a bit like "riding the brakes". Front calipers are easy to rebuild, rears are NOT! The biggest issue with my 75 when I purchased it was one of the rear calipers did exactly this and trashed both the pads and the rotor. Thanks for the info! That very well may be the case. I've already bought all 4 brake hoses to install, hoping that maybe the brake hose on that caliper is failing internally and causing the dragging. |
Fart/4 Can someone point me to brake rotor and pads May 12 2026, 08:35 PM
Montreal914 Call Eric Shea at PMB. :)
https://pmbperformanc... May 12 2026, 08:38 PM
930cabman
https://pmbperforman... May 13 2026, 04:58 AM
914rrr I'm looking as well.
Thing is, I need almost a... May 13 2026, 06:24 AM
Tom1394racing
Thing is, I need almost ... May 13 2026, 06:30 AM
914rrr
Thing is, I need almost... May 13 2026, 01:29 PM
Dynosoar11
Thing is, I need almost ... May 13 2026, 04:09 PM
914rrr
Thing is, I need almost... May 13 2026, 04:39 PM
914rrr I need some local assistance desperately.
This w... May 15 2026, 09:31 AM
BillC
This ... May 15 2026, 11:35 AM
914rrr Calling "old timers", I'm now befudd... May 15 2026, 07:15 PM
914rrr A pic of my rear caliper.
May 15 2026, 08:08 PM
914rrr I think I've cracked the code using Rockauto a... May 16 2026, 12:51 AM
914rrr Another part # for 914 rear brakes on AutoNation f... May 16 2026, 09:00 AM
914rrr Here's an update. Received the pads and hardwa... May 24 2026, 08:00 PM
Literati914
Here's an update. Received the pads and hardw... May 25 2026, 10:03 AM
Literati914 Just a note, these are the ones I used at the rear... May 25 2026, 10:09 AM
914rrr Sorry, duplicate post Jul 24 2026, 07:04 AM
914rrr Tech question regarding 914 caliper piston boot cl... Jul 24 2026, 08:37 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th July 2026 - 10:57 AM |
