| trojanhorsepower |
May 17 2026, 08:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,035 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
All,
I have been enjoying my car but have a recurring issue. Starts great Runs fine for maybe 20 min Starts to once in a while act like it turned off for just a 1/2 sec then comes back on - causing the car to lurch and the shifter to jump After about 30 or 40 min the car dies if stopped and allowed to idle. It just drops off spools down to nothing, It restarts if you hold the gas peddle all the way down. Sometime when it restarts it is weak, then it goes fine. As long as the car is in gear and moving it does not die. It will continue to do this until I get home. If I am coordinated enough I can shift into neutral, work the brake with my left foot and keep the RPMs up a bit with my left and it seems fine (no stumbling or trying to die at higher RPMs) but if I come to a light, stop and let it idle it will just idle down to nothing. Sometimes when I get home it will idle fine until I turn it off. Other times it just dies. Seems to pull great all through the range Always restarts Any ideas where to start? Thanks Peter |
| Ishley |
May 17 2026, 08:56 AM
Member ![]() ![]() Group: Members Posts: 348 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
First off what year car. What modifications are in the car? Engine size, cam etc. Are you running original fuel injection or carbs? If carbs what type. What did you last do to the car? Have you maintained the fuel system. Fuel filter good? Fuel pressure good?
trojanhorsepower Engine trouble May 17 2026, 08:14 AM
emerygt350
First off what year car. What modifications are i... May 17 2026, 11:27 AM
trojanhorsepower Hmmm yeah probably should have included all that..... May 17 2026, 01:31 PM
wonkipop
Hmmm yeah probably should have included all that.... May 17 2026, 02:41 PM
trojanhorsepower D Jet May 17 2026, 02:50 PM
wonkipop
D Jet
can't help with d jet.
but something... May 17 2026, 03:44 PM
trojanhorsepower Sounds probable. I was ever happy with the fuel l... May 17 2026, 04:00 PM
Ishley Difficult to tell... but it sounds electrical to m... May 17 2026, 05:24 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th May 2026 - 06:28 PM |
