> Engine trouble, Dies at idle
trojanhorsepower
post May 17 2026, 08:14 AM
All,
I have been enjoying my car but have a recurring issue.
Starts great
Runs fine for maybe 20 min
Starts to once in a while act like it turned off for just a 1/2 sec then comes back on - causing the car to lurch and the shifter to jump
After about 30 or 40 min the car dies if stopped and allowed to idle. It just drops off spools down to nothing,
It restarts if you hold the gas peddle all the way down. Sometime when it restarts it is weak, then it goes fine.
As long as the car is in gear and moving it does not die.
It will continue to do this until I get home. If I am coordinated enough I can shift into neutral, work the brake with my left foot and keep the RPMs up a bit with my left and it seems fine (no stumbling or trying to die at higher RPMs) but if I come to a light, stop and let it idle it will just idle down to nothing.
Sometimes when I get home it will idle fine until I turn it off. Other times it just dies.
Seems to pull great all through the range
Always restarts
Any ideas where to start?
Thanks
Peter
trojanhorsepower
post May 17 2026, 02:50 PM
D Jet
wonkipop
post May 17 2026, 03:44 PM
QUOTE(trojanhorsepower @ May 17 2026, 02:50 PM) *
D Jet
can't help with d jet.
but something it could be with either type is a collapsing fuel line.
a tight bend somewhere.
bit of a classic symptom where it runs fine for a while but after a period running the fuel line begins to collapse and strangle off the fuel supply. often will come back to life if you gas it but left to idle will just die. could be up under the fuel tank or if the pump is still at the back under the engine where the lines come into the pump. look for tight bends in the line which might look crinkled in where they are curved around a bend.
6 User(s) are reading this topic (3 Guests and 1 Anonymous Users)
2 Members: Alden, brant
- Lo-Fi Version Time is now: 17th May 2026 - 06:28 PM
