> Hydraulic clutch (part 2), w/ pics for Ginter & y'all
airsix
post Jun 4 2003, 02:14 AM
I have bees in my epiglotis
Had lots of requests for pictures of the hydraulic clutch conversion, so here you go.
Things that have changed since the last episode:
1) re-did the slave mount. Got rid of the stupid pulley bracket and did it right.
2) MC install was a major PITA. Had to cut a chunk out of the pan and make a mounting surface that was flat and angled in the right direction.
3) I found that there is not enough room up next to the steering rack to cut a line and re-flare it after you have discovered that you slipped the flare-nut on backwards before plumbing all the lines (ARRRRGGG!!!!). That's ok, I did a better job the second time anyway.
4) Rebuilt pedal box while I was in there (Had the bronze bushing kit laying around). Thanks Lawrenece for your comments about this last week. I almost skipped it and saved it for another time. Glad I rebuilt it. Big difference.
Ok, here's the pics. (No pic from inside the car 'cuz you can't see anything with the pedal box in the way)
-Ben M.
airsix
post Jun 5 2003, 01:52 AM
QUOTE(Gint @ Jun 4 2003, 07:28 PM)
I take it you used the inboard end of the clutch pivot rod for the MC? That would explain the cylinder being inboard of the brake MC?
Correct. I figured that was the only practical way to retain the stock clutch pedal.
-Ben M.
- Lo-Fi Version Time is now: 2nd April 2026 - 10:47 AM
