> Engine trouble, Dies at idle
trojanhorsepower
post May 17 2026, 08:14 AM
All,
I have been enjoying my car but have a recurring issue.
Starts great
Runs fine for maybe 20 min
Starts to once in a while act like it turned off for just a 1/2 sec then comes back on - causing the car to lurch and the shifter to jump
After about 30 or 40 min the car dies if stopped and allowed to idle. It just drops off spools down to nothing,
It restarts if you hold the gas peddle all the way down. Sometime when it restarts it is weak, then it goes fine.
As long as the car is in gear and moving it does not die.
It will continue to do this until I get home. If I am coordinated enough I can shift into neutral, work the brake with my left foot and keep the RPMs up a bit with my left and it seems fine (no stumbling or trying to die at higher RPMs) but if I come to a light, stop and let it idle it will just idle down to nothing.
Sometimes when I get home it will idle fine until I turn it off. Other times it just dies.
Seems to pull great all through the range
Always restarts
Any ideas where to start?
Thanks
Peter
BillC
post May 21 2026, 07:25 AM
Hopefully this is just a silly question, but what cam is in your engine? Since it's a 2056, it's been rebuilt (obviously), so they could have changed the cam.
Your symptoms sound a lot like what I was chasing on my car when I was first trying to get it running again -- it would run fairly well at higher RPMS, but it would just wind down and die at idle. In my case, the rebuilder put a too-aggressive cam in the engine that isn't really compatible with D-Jet.
Do you have a vacuum gauge? Have you checked your vacuum levels at idle? If so, what do you see when it's running and also when it run downs and dies? If you see fairly low vacuum at idle, like 8-12", and that vacuum goes toward 0 before the engine dies, it might be your cam.
I was finally able to get my engine to idle fairly reliably on D-Jet, but I had to set the idle to 1600 RPM to make that happen.
trojanhorsepower   Engine trouble   May 17 2026, 08:14 AM
Ishley   First off what year car. What modifications are in...   May 17 2026, 08:56 AM
emerygt350   First off what year car. What modifications are i...   May 17 2026, 11:27 AM
trojanhorsepower   Hmmm yeah probably should have included all that.....   May 17 2026, 01:31 PM
wonkipop   Hmmm yeah probably should have included all that....   May 17 2026, 02:41 PM
trojanhorsepower   D Jet   May 17 2026, 02:50 PM
wonkipop   D Jet can't help with d jet. but something...   May 17 2026, 03:44 PM
trojanhorsepower   Sounds probable. I was ever happy with the fuel l...   May 17 2026, 04:00 PM
Ishley   Difficult to tell... but it sounds electrical to m...   May 17 2026, 05:24 PM
emerygt350   Has it always done this?   May 17 2026, 06:59 PM
trojanhorsepower   Post restoration, yes. To some degree. It is wor...   May 18 2026, 02:45 PM
Olympic 914   I had a similar issue. It was the CHT sensor, int...   May 18 2026, 04:24 PM
emerygt350   Yes, cht is what I suspect as well. Sounds like i...   May 18 2026, 05:06 PM
trojanhorsepower   OK is the theory behind the CHT sensor being bad t...   May 19 2026, 04:15 PM
emerygt350   OK is the theory behind the CHT sensor being bad ...   May 19 2026, 04:30 PM
Olympic 914   The ECU needs to see some resistance from the CH...   May 19 2026, 05:28 PM
trojanhorsepower   OK, I got some numbers off the ECU. Unfortunately...   May 19 2026, 05:13 PM
emerygt350   A bad connection can mean more or intermittent cha...   May 20 2026, 05:36 AM
trojanhorsepower   OK, Ill keep looking for MPS #s. It does not appe...   May 20 2026, 06:30 PM
trojanhorsepower   Got Em! 0280100037   May 20 2026, 06:46 PM
emerygt350   Ahh... That is what I feared. You have a 73 mps a...   May 21 2026, 04:34 AM
emerygt350   Now that I have a moment to type... Was this orgia...   May 21 2026, 06:18 AM
BillC   Hopefully this is just a silly question, but what ...   May 21 2026, 07:25 AM
emerygt350   If you are running the timing retard currently, re...   May 21 2026, 07:35 AM
trojanhorsepower   OK, Thanks all, No idea what the cam is. IT came ...   May 21 2026, 04:09 PM
trojanhorsepower   Forgot: The MPS was tested when we put the engine...   May 21 2026, 04:22 PM
emerygt350   Do you have a mighty vac? Easy to test the mps to...   May 21 2026, 04:58 PM
trojanhorsepower   Yes, I will test the MPS. Dizzy is a correct 2l I ...   May 21 2026, 05:46 PM
trojanhorsepower   No numbers left on the other computer   May 21 2026, 05:54 PM
emerygt350   Hmm. No way to know what that ECU is from without...   May 21 2026, 06:37 PM
trojanhorsepower   I have the ECU open and don't see any numbers ...   May 22 2026, 05:08 PM
emerygt350   Looks good. To simplify troubleshooting you may w...   May 22 2026, 05:56 PM
trojanhorsepower   Is the retard line the one on the green one?   May 22 2026, 07:21 PM
emerygt350   Yes.   May 23 2026, 04:59 AM
trojanhorsepower   OK. Cap both ends? TB and distributer?   May 23 2026, 01:19 PM
trojanhorsepower   Just tested the mps and it passed. Less then 1...   May 23 2026, 02:03 PM
emerygt350   Just cap the tb port. Good news on the mps. Did ...   May 23 2026, 02:30 PM
Olympic 914   There should be a label inside the ECU where the h...   May 23 2026, 04:02 PM
trojanhorsepower   This is the insides   May 23 2026, 04:55 PM
trojanhorsepower   Anyone have a good 74 mps they want to sell or tra...   May 23 2026, 05:23 PM
emerygt350   You could try it and see. If it struggles then pu...   May 23 2026, 05:31 PM
- Lo-Fi Version Time is now: 9th June 2026 - 07:45 PM
