> Spaced Out, What would you do?
Shivers
post May 21 2026, 11:07 AM
Hi guys: I'm working on my trailing arms. Won't be long till it is time to reassemble. I tried the search, gave up and decided to ask directly. I have new hubs, 5x130. My rear flares are GT flares that I am adding 2" in width to each one in the rear. I would really appreciate your opinions on spacers. I need to get lugs on these hubs before I install them. Which spacer in your experience is safer. Long lugs or short lugs bolted to the spacer.
Gentleman, what say you? (IMG:style_emoticons/default/idea.gif)
I borrowed the base picture then added my junk to it. Carving, some autocross and I hope a track day now and then. Thanks
Charles Freeborn
post May 22 2026, 10:58 AM
Def long lugs and spacers. I use H&R. You can also check with Eric at PMB. He's got lugs, etc. BTW, you can change studs with the hubs on the car (at least on mi car) . Have to pull calipers (anyway), any backing plates, etc.
Shivers
post May 22 2026, 03:41 PM
QUOTE(Charles Freeborn @ May 22 2026, 09:58 AM) *
You must have some kind of really cool tool. All I have is a press. And an e brake plate, and that can not be removed with out pulling the hubs. I still have an engine to rebuild or reseal, had it parked for a while, so slow and steady is my plan. Thanks
Shivers   Spaced Out   May 21 2026, 11:07 AM
brant   Bolted together spacers used to be taboo for racin...   May 21 2026, 01:18 PM
flxzcat   The one thing that has really bugged me is that 91...   May 21 2026, 03:35 PM
Shivers   The one thing that has really bugged me is that 9...   May 21 2026, 08:04 PM
GregAmy   The one thing that has really bugged me is that 9...   May 22 2026, 05:38 AM
flxzcat   Email Chris, see if he has these in stock. I use ...   Jun 26 2026, 03:02 PM
brant   Late cars are hub centric   May 21 2026, 05:15 PM
Charles Freeborn   Def long lugs and spacers. I use H&R. You can ...   May 22 2026, 10:58 AM
Shivers   Def long lugs and spacers. I use H&R. You can...   May 22 2026, 03:41 PM
Charles Freeborn   Def long lugs and spacers. I use H&R. You ca...   May 22 2026, 03:51 PM
Ninja   Bolted together spacers used to be taboo for raci...   May 22 2026, 04:28 PM
stownsen914   I've also not been a fan of the adapter style ...   May 23 2026, 11:22 AM
mlindner   Yes Porsche did. This is my 1998 Carrera S, wide b...   May 24 2026, 05:28 AM
mlindner   Just FYI, also have them on my 914-6 GT Tribute fr...   May 24 2026, 05:52 AM
GregAmy   Spacers, regardless of material, are not in and of...   May 24 2026, 06:35 AM
slivel   Front and rear on my car. No issues with wheel be...   May 25 2026, 11:07 AM
campbellcj   Same on my car; spacers F&R for >15 yrs and...   Jun 3 2026, 07:49 AM
stownsen914   Interesting, sounds like folks have had good exper...   Jun 4 2026, 08:16 AM
sixnotfour   A bit of Lathe work,, Upgraded Rears.. 5-lug spec...   Sep 9 2026, 02:28 PM
914werke   Ive got a vintage issue of VW & Porsche somewh...   Sep 9 2026, 05:09 PM
mepstein   Didn't Porsche use bolt on spacers on some of ...   Sep 9 2026, 05:24 PM
sixnotfour   @914werke , These are not move out, But does have ...   Sep 9 2026, 09:03 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th October 2026 - 11:40 PM
