> Spaced Out, What would you do?
Shivers
post May 21 2026, 11:07 AM
Hi guys: I'm working on my trailing arms. Won't be long till it is time to reassemble. I tried the search, gave up and decided to ask directly. I have new hubs, 5x130. My rear flares are GT flares that I am adding 2" in width to each one in the rear. I would really appreciate your opinions on spacers. I need to get lugs on these hubs before I install them. Which spacer in your experience is safer. Long lugs or short lugs bolted to the spacer.
Gentleman, what say you? (IMG:style_emoticons/default/idea.gif)
I borrowed the base picture then added my junk to it. Carving, some autocross and I hope a track day now and then. Thanks
Ninja
post May 22 2026, 04:28 PM
QUOTE(brant @ May 21 2026, 02:18 PM) *
Bolted together spacers used to be taboo for racing
I would buy TUV approved spacers
In fact run one inch German spacers on my racecar
Then buy the correct length of studs
QUOTE(brant @ May 21 2026, 06:15 PM) *
Late cars are hub centric
Later front hubs are concentric; the rears never were (stock 4 or 6 cylinder).
I'm with Brant. I've always loathed "adaptors" with a second set of studs mounted in the adaptor.
Maybe the newer stuff is better...
TUV rated stuff is probably pretty good, those Europeans are a picky bunch!
Now, if you made it out of titanium, I wouldn't have any qualms on using it. Just $$$
One thing that is often overlooked is where the wheel bearing sits in regards to the rubber footprint on the ground.
Most of the time the bearing needs to be "centered" in the tire footprint. Get this offset wrong and all sorts of strange issues can crop up.
I'm not sure if the 914 stock bearing is actually centered. I'd try to "mimic" the stock position in my wider footprint.
Front issues, bearing strength/life (minor) and steering effort can be a problem as you can change your scrub radius.
Rear is a BIG hit on bearing strength/life and it will make alignments far more critical.
Both front and rear will usually make bump steer issues worse.
Big time "track width" changes need proper engineering.
Most factory warranties for new stuff get voided over wheel offset changes. They won't pay for anything suspension or wheel bearing related if you change stuff up.
Be very careful when making these changes.
One again, @ChrisFoley is who I'd want to run any track changes by before I actually did them.
I LOVE the look of that white car, just BADASSED!
Ninja approved! (IMG:style_emoticons/default/ninja.gif)
I just wouldn't want a rear wheel bearing to fail at triple digit speeds...
Shivers   Spaced Out   May 21 2026, 11:07 AM
brant   Bolted together spacers used to be taboo for racin...   May 21 2026, 01:18 PM
flxzcat   The one thing that has really bugged me is that 91...   May 21 2026, 03:35 PM
Shivers   The one thing that has really bugged me is that 9...   May 21 2026, 08:04 PM
GregAmy   The one thing that has really bugged me is that 9...   May 22 2026, 05:38 AM
flxzcat   Email Chris, see if he has these in stock. I use ...   Jun 26 2026, 03:02 PM
brant   Late cars are hub centric   May 21 2026, 05:15 PM
Charles Freeborn   Def long lugs and spacers. I use H&R. You can ...   May 22 2026, 10:58 AM
Shivers   Def long lugs and spacers. I use H&R. You can...   May 22 2026, 03:41 PM
Charles Freeborn   Def long lugs and spacers. I use H&R. You ca...   May 22 2026, 03:51 PM
Ninja   Bolted together spacers used to be taboo for raci...   May 22 2026, 04:28 PM
stownsen914   I've also not been a fan of the adapter style ...   May 23 2026, 11:22 AM
mlindner   Yes Porsche did. This is my 1998 Carrera S, wide b...   May 24 2026, 05:28 AM
mlindner   Just FYI, also have them on my 914-6 GT Tribute fr...   May 24 2026, 05:52 AM
GregAmy   Spacers, regardless of material, are not in and of...   May 24 2026, 06:35 AM
slivel   Front and rear on my car. No issues with wheel be...   May 25 2026, 11:07 AM
campbellcj   Same on my car; spacers F&R for >15 yrs and...   Jun 3 2026, 07:49 AM
stownsen914   Interesting, sounds like folks have had good exper...   Jun 4 2026, 08:16 AM
sixnotfour   A bit of Lathe work,, Upgraded Rears.. 5-lug spec...   Sep 9 2026, 02:28 PM
914werke   Ive got a vintage issue of VW & Porsche somewh...   Sep 9 2026, 05:09 PM
mepstein   Didn't Porsche use bolt on spacers on some of ...   Sep 9 2026, 05:24 PM
sixnotfour   @914werke , These are not move out, But does have ...   Sep 9 2026, 09:03 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 4th October 2026 - 11:40 PM
