| Shivers |
May 22 2026, 08:26 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,480 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I'm sure you guys are sick of this subject but I am in the throws of it. I've been reading everything I could find here on the subject and it is pretty straight forward. But everywhere I read it says to use the 1970 through 1973 911 plates. Funny how those plates are near 250.00 - 300.00 now. For one. I couldn't do that. So I went to two different places and got two 1965 - 1969 e brake plates for 110.00 and that included shipping. In the picture it looks the same, maybe I would need to do a little work on it, maybe a lot but my labor is free to me.
I received one last night so at 4:00am I'm making coffee and measuring the hole size of the plate and then the bearing carrier on the trailing arm. Both were 4 1/4" so I tried to slip the plate on and it only went so far. Well it took me a second but I was trying to put a square peg in a round hole. So I dropped the step on the side of the screw bosses 1/2" - 5/8" and radiused the screw bosses. I also added a radius at the front of the boss because the plate in the hole has a radius where the carrier is to mate with the plate. Got that done and the plate slipped right on to the carrier. I checked that the plate would fit inside my disk correctly and that it would also fit right when it had a hub in place with the disk. It does. So here is my question for you all, what kind of boogieman is going to jump out when I least expect it. So far it is smooth sailing but I really like a plan for everything, especially potential problems. Anyone know what I need to watch for? Thanks ![]() ![]() ![]() ![]() |
| Jack Standz |
May 23 2026, 12:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 879 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
A few possibilities that come to mind.
You will need a "stop block" feature where the bottom end of the brake shoes push against. It needs to be fairly robust and in the right location. Some weld an approximately 45 mm(?) rectangle on the backing plate and some weld it on the trailing arm. You also may have to reroute (rebend) the rear hard brake lines because your M calipers may have the brake line inlet in a location that prevents bleeding all the air from the brake lines when using a stock hard line. You probably will need a spacer between your calipers and trailing arm ears (again "M" calipers and vented 911 rotors). IIRC it's a spacer around 5 mm. IIRC some rotors may be a little too large in diameter and will need machining. On our '74 with this modification, the mounting holes in the backing plate had to be enlarged as they were slightly small and slightly off-center. Yours look ok. |
Shivers 911 e brake conversion May 22 2026, 08:26 PM
Superhawk996
Some weld an approximately 45 mm(?) rectangle on ... May 23 2026, 03:32 AM
sixnotfour Don't forget the Bearing Lid... Not shown in p... May 23 2026, 04:22 AM
Luke M When I did my Boxster rear brake conversion I ran ... May 23 2026, 09:13 AM
Shivers
When I did my Boxster rear brake conversion I ran... May 23 2026, 12:54 PM
Jack Standz
Some weld an approximately 45 mm(?) rectangle on... May 23 2026, 02:25 PM
Shivers The 1965-1989 shoes and interior parts kit fit the... Jun 15 2026, 06:57 PM
Shivers I guess this is the reveal. I'm going to post ... Jul 13 2026, 05:36 PM
sixnotfour Gettin er Done.. :welder: :beer2: Jul 13 2026, 09:01 PM
porschetub Nice work ,what are your plans for calipers ? ,che... Jul 13 2026, 10:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th July 2026 - 11:31 PM |
