| Shivers |
May 22 2026, 08:26 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,480 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I'm sure you guys are sick of this subject but I am in the throws of it. I've been reading everything I could find here on the subject and it is pretty straight forward. But everywhere I read it says to use the 1970 through 1973 911 plates. Funny how those plates are near 250.00 - 300.00 now. For one. I couldn't do that. So I went to two different places and got two 1965 - 1969 e brake plates for 110.00 and that included shipping. In the picture it looks the same, maybe I would need to do a little work on it, maybe a lot but my labor is free to me.
I received one last night so at 4:00am I'm making coffee and measuring the hole size of the plate and then the bearing carrier on the trailing arm. Both were 4 1/4" so I tried to slip the plate on and it only went so far. Well it took me a second but I was trying to put a square peg in a round hole. So I dropped the step on the side of the screw bosses 1/2" - 5/8" and radiused the screw bosses. I also added a radius at the front of the boss because the plate in the hole has a radius where the carrier is to mate with the plate. Got that done and the plate slipped right on to the carrier. I checked that the plate would fit inside my disk correctly and that it would also fit right when it had a hub in place with the disk. It does. So here is my question for you all, what kind of boogieman is going to jump out when I least expect it. So far it is smooth sailing but I really like a plan for everything, especially potential problems. Anyone know what I need to watch for? Thanks ![]() ![]() ![]() ![]() |
| Luke M |
May 23 2026, 09:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,555 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
When I did my Boxster rear brake conversion I ran into a few issues. Watch the rear e-brake shoes that you buy. They aren't all the same width. A few sets that I installed where too wide and the rotor wouldn't sit against the hub. It took some work to figure out which shoes that I needed. The parts guy at Stoddard was very helpful in measuring a few different sets for me. I'd have to dig through some paperwork to find the part #. Like stated above, you'll need to weld on some e-brake plates. I think the Tangerine Racing kit comes with this part. I ended up making my own plates then welding them on. I used a cam action bracket to actuate my e-brake shoes. I believe a few different members have used this similar setup. On the backing plates I ended up using the 69-73 backing plates. The 74 up used the larger wheel bearings and wider mounting plates. With the 69-73 plates you'll need to grind a little off the mounting tabs on the control arms. You'll also need two bearing retainer plates as well. I didn't see those in your pics. Again for whatever year plates you have. I used the later 911 hubs so I needed a small spacer between the hub and bearing. I'm using the 911 100 mm 6 bolt stubs and cv's with custom axles. The rotors used are a 911 vented rear from 69-83.
If using 911 rear calipers you'll need a small spacer between the calipers and control arm mounting ears. I didn't have any clearance issues with the caliper to rotor when using the M calipers. Now using the Boxster calipers there's a rear brake pad mod that needs to be done. Attached image(s)
Shivers 911 e brake conversion May 22 2026, 08:26 PM
Jack Standz A few possibilities that come to mind.
You will... May 23 2026, 12:13 AM
Superhawk996
Some weld an approximately 45 mm(?) rectangle on ... May 23 2026, 03:32 AM
sixnotfour Don't forget the Bearing Lid... Not shown in p... May 23 2026, 04:22 AM
Shivers
When I did my Boxster rear brake conversion I ran... May 23 2026, 12:54 PM
Jack Standz
Some weld an approximately 45 mm(?) rectangle on... May 23 2026, 02:25 PM
Shivers The 1965-1989 shoes and interior parts kit fit the... Jun 15 2026, 06:57 PM
Shivers I guess this is the reveal. I'm going to post ... Jul 13 2026, 05:36 PM
sixnotfour Gettin er Done.. :welder: :beer2: Jul 13 2026, 09:01 PM
porschetub Nice work ,what are your plans for calipers ? ,che... Jul 13 2026, 10:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th July 2026 - 11:32 PM |
