> 911 e brake conversion, 65-69 backing plates
Shivers
post May 22 2026, 08:26 PM
I'm sure you guys are sick of this subject but I am in the throws of it. I've been reading everything I could find here on the subject and it is pretty straight forward. But everywhere I read it says to use the 1970 through 1973 911 plates. Funny how those plates are near 250.00 - 300.00 now. For one. I couldn't do that. So I went to two different places and got two 1965 - 1969 e brake plates for 110.00 and that included shipping. In the picture it looks the same, maybe I would need to do a little work on it, maybe a lot but my labor is free to me.
I received one last night so at 4:00am I'm making coffee and measuring the hole size of the plate and then the bearing carrier on the trailing arm. Both were 4 1/4" so I tried to slip the plate on and it only went so far. Well it took me a second but I was trying to put a square peg in a round hole. So I dropped the step on the side of the screw bosses 1/2" - 5/8" and radiused the screw bosses. I also added a radius at the front of the boss because the plate in the hole has a radius where the carrier is to mate with the plate. Got that done and the plate slipped right on to the carrier. I checked that the plate would fit inside my disk correctly and that it would also fit right when it had a hub in place with the disk. It does.
So here is my question for you all, what kind of boogieman is going to jump out when I least expect it. So far it is smooth sailing but I really like a plan for everything, especially potential problems. Anyone know what I need to watch for? Thanks
Jack Standz
post May 23 2026, 02:25 PM
QUOTE(Superhawk996 @ May 23 2026, 04:32 PM) *
QUOTE(Jack Standz @ May 23 2026, 02:13 AM) *
Some weld an approximately 45 mm(?) rectangle on the backing plate and some weld it on the trailing arm.
The reaction block MUST be welded to the trailing arm.
Ours is welded to the trailing arm where it should be. But, you must be aware that some run without any parking brakes. (IMG:style_emoticons/default/blink.gif)
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: Artfrombama
- Lo-Fi Version Time is now: 13th July 2026 - 11:31 PM
