| burlybryan |
May 25 2026, 10:12 AM
Member ![]() ![]() Group: Members Posts: 149 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I have a buddy with a Rennshift shifter and Tangerine rod and linkage. He lost shifting while driving recently and from what I can tell, the rod separated from the splined linkage at the trans. I removed the set screw at the rear linkage and it not a cone screw.
Can someone confirm if these ever came with just basic set screws or were they always cone screws. I haven't pulled it apart to see if there is a remnant cone portion stuck in the shaft, but wanted to get an idea of what is supposed to be there. Chris' kit shows cone screws. Thanks! |
| mlindner |
May 25 2026, 12:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,780 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
And Chris side shift Alignment Tool is the best thing since sliced bread. It is so easy to use and the results are dead on. Had my 914 for 45 years and the shift pattern and gear engagement has never been this good. Best, Mark
burlybryan Tangering shift rod/linkage set screw question May 25 2026, 10:12 AM
TRP I am pretty confident that both set screws provide... May 25 2026, 11:01 AM
Jack Standz Don't know if Chis made different versions ove... May 25 2026, 11:38 AM
ChrisFoley
I have a buddy with a Rennshift shifter and Tange... May 25 2026, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 01:47 PM |
