> Synchro Replacement, 1st Gear
Chaznaster
post Jan 20 2026, 06:31 PM
Hi.
I am planning to address the grinding I get when going into 1st gear at anything faster than a full stop. The Pelican article on the replacing first gear seems pretty good, and I plan to search these pages for nuggets of wisdom before starting.
This thing has been grinding as long as I have had it and certainly long before that ... so I figure it is in pretty bad shape.
Pelican suggests the following parts: slider, shift fork, synchro ring and brake band, dog teeth, and maybe first gear if it is worn. I plan to open it up before getting parts - and I assume they are all available without much trouble.
I'd appreciate your thoughts on tackling this project as well as any advice.
Thanks. Christian
Jack Standz
post May 26 2026, 12:40 AM
Chaznaster   Synchro Replacement   Jan 20 2026, 06:31 PM
mgphoto   Hi. I am planning to address the grinding I get...   Jan 20 2026, 07:09 PM
Dave_Darling   You do know there isn’t any syncro from 2nd to ...   Jan 21 2026, 02:22 AM
brant   You do know there isn’t any syncro from 2nd to...   Jan 21 2026, 08:06 AM
ctc911ctc   You do know there isn’t any syncro from 2nd to...   Jan 21 2026, 12:39 PM
rfinegan   Dr Evil may have some of the parts both new or us...   Jan 20 2026, 07:38 PM
mepstein   My experience, after rebuilding a couple dozen tra...   Jan 20 2026, 07:39 PM
914werke   Hi. I am planning to address the grinding I get w...   Jan 21 2026, 10:05 AM
Ninja   Dr Evil may have some of the parts both new or u...   Jan 21 2026, 10:05 AM
mgphoto   Has anyone on this board ever down shifted from 30...   Jan 21 2026, 12:39 PM
ctc911ctc   The difference in gear-spin is pretty severe at th...   Jan 21 2026, 12:53 PM
brant   Has anyone on this board ever down shifted from 3...   Jan 21 2026, 12:56 PM
Dave_Darling   Has anyone on this board ever down shifted from 3...   Jan 23 2026, 02:49 AM
mgphoto   Please observe parts 41, 8 and 9. Syncro only on o...   Jan 21 2026, 12:46 PM
ctc911ctc   You may find this helpful: http://www.914world.co...   Jan 21 2026, 12:50 PM
Jack Standz   Please observe parts 41, 8 and 9. Syncro only on ...   Jan 21 2026, 03:06 PM
ctc911ctc   43 is $$$$$ Dr. Evil sol...   Jan 21 2026, 03:18 PM
dr914@autoatlanta.com   easily done with the transmission in the car, just...   Jan 21 2026, 03:47 PM
Jack Standz   43 is $$$$$ Dr. Evil so...   Jan 21 2026, 04:15 PM
Chaznaster   I've been away from this forum for some time (...   Jan 21 2026, 06:30 PM
worn   I am going to try to it with the trans in the car...   Jan 21 2026, 07:12 PM
targa72e   I have read in some other post about getting 1st g...   Jan 21 2026, 10:57 PM
rfinegan   A little sneak peak of what is involved: youtube l...   Jan 22 2026, 08:38 AM
Chaznaster   A little sneak peak of what is involved: youtube ...   Jan 22 2026, 07:32 PM
Chaznaster   I finally found some time to tear into the transmi...   Feb 15 2026, 02:43 PM
mepstein   If first gear is gone, second is usually close beh...   Feb 15 2026, 03:09 PM
ctc911ctc   If first gear is gone, second is usually close be...   Feb 16 2026, 03:31 PM
mlindner   I do have the tools needed for a small rental fee....   Feb 15 2026, 03:43 PM
jim_hoyland   :) Nice pics, thanks for posting   Feb 15 2026, 04:03 PM
914werke   Sucker is toast   Feb 16 2026, 12:25 PM
rudedude   If you haven't spend some time on the bird sit...   Feb 16 2026, 02:40 PM
Chaznaster   Thanks to all for the confirmation and advice. I ...   Feb 16 2026, 05:40 PM
ctc911ctc   Sent you a pm Thanks to all for the confirmati...   Feb 16 2026, 06:42 PM
Chaznaster   Today I separated the dog teeth and pressed in the...   Mar 1 2026, 02:21 PM
Ninja   You might have gotten lucky! :ninja: Finding ...   Mar 1 2026, 03:51 PM
brant   Zzz you’re half way there and you have the video...   Mar 1 2026, 04:12 PM
Chaznaster   I am going to go for it. Will report back!   Mar 5 2026, 07:20 PM
Chaznaster   So I finally got around to dropping the engine in ...   Mar 30 2026, 05:30 PM
Montreal914   Not familiar with the tangerine plate but the cros...   Mar 30 2026, 06:25 PM
Chaznaster   The transmission is off the engine. That was easie...   Apr 6 2026, 06:22 PM
Montreal914   :) :smash: :driving:   Apr 6 2026, 08:39 PM
Chaznaster   :) :smash: :driving: Thanks. I had be...   Apr 7 2026, 05:25 PM
rudedude   Need a good 8mm triple square to remove the bolts....   Apr 7 2026, 07:44 AM
Montreal914   Unfortunately I do not. Numbers gets superceded. ...   Apr 7 2026, 11:27 PM
Chaznaster   I pulled the stack today. The 3 dog teeth and slid...   Apr 14 2026, 05:15 PM
Chaznaster   I got to some disassembly today and have questions...   Apr 18 2026, 02:35 PM
Jack Standz   To answer your question: "For 2 and 3 gear ...   Apr 18 2026, 03:20 PM
Chaznaster   I got the rest disassembled this morning. Synchr...   Apr 19 2026, 07:57 AM
ctc911ctc   Dog Teeth's job is to avoid lock-ups but can b...   Apr 19 2026, 08:03 PM
Chaznaster   Excellent news to report! I finished the reb...   May 25 2026, 05:15 PM
BillC   Excellent news to report! I finished the re...   May 26 2026, 12:00 PM
Dr Evil   Excellent news to report! I finished the re...   Jun 3 2026, 08:21 AM
Jack Standz   :driving:   May 26 2026, 12:40 AM
craig downs   I've read never downshift into 1st   May 29 2026, 08:28 PM
Dr Evil   I've read never downshift into 1st You are c...   Jun 3 2026, 08:20 AM
mgphoto   I've read never downshift into 1st You are ...   Jun 4 2026, 09:14 AM
dtmehall   i've done it for 53 years! (carefully)   May 29 2026, 08:31 PM
Chaznaster   I certainly do not downshift to first at high spee...   May 30 2026, 09:34 AM
Chaznaster   Thanks for the tip. I had always gone into first ...   Jun 7 2026, 06:31 PM
- Lo-Fi Version Time is now: 22nd November 2026 - 03:17 PM
