| Lilchopshop |
Dec 3 2023, 08:15 PM
Member ![]() ![]() Group: Members Posts: 118 Joined: 17-February 20 From: New York Member No.: 23,932 Region Association: North East States |
Hi All,
My name is Aaron. I've been lurking on this site for years, learning from all of you who are kind enough to share your projects and the challenges that go along with them. In an attempt to keep me motivated on my project and as a way to create a place for me to ask questions as they come up (which they will, frequently), I decided it was time to start a proper build thread. I’m not a novice when it comes to tools, fabricating and most things automotive, but I’ve never attempted an engine swap before, and most things electrical tend to stress me out. That being said, I love a good challenge and I’m not afraid to fail. I purchased this car in February of 2020, just before Covid lockdown. I got off to a pretty good start repairing the rust and trying to make a solid chassis for what I thought was going to be a stock-ish restoration (some of that work documented here: http://www.914world.com/bbs2/index.php?sho...ty+jack+points). Then, after watching all the great engine-swap builds on this site, I changed my mind. I knew I wanted more horsepower, but I couldn’t justify the cost of an air-cooled Porsche 6-cyl and I didn’t want to lose the trunk to a big V8. For a while, I was considering keeping the original engine from the car and using a tunable fuel injection package, but for the total cost, the bang for the buck just didn’t seem there. So, I settled on the Suby engine. After some research and some purchasing mistakes, I ended up buying a 2002 legacy outback donor vehicle with an EG25 engine. I harvested the engine, the ECU and whatever else seemed valuable. After selling off the old Porsche engine, transmission, all of the FI components and the saleable parts from the donor Subaru, I probably ended up in the black, financially. Since buying the car in 2020, I’ve gotten pulled away by many other, more important projects, so I’ve only been able to do little stints of work on the car. I’m optimistic this time, that I will be able to finally dedicate some quality time this winter and hopefully make some real headway. I haven’t been great at documenting the little things I’ve done on the car in the last 2 years, so I’ll start this thread off with some of the things I did actually get pictures of and a summary of where I’m at now. The day we met: ![]() The first attempt at a Suby Engine (EJ22): ![]() The second attempt (complete donor vehicle): ![]() My crazy, home-built cable shift linkage: My home-built engine cradle: Shifter from a boxter (slightly modified): Some suspension ear reinforcement: ![]() |
| Jack Standz |
May 29 2026, 01:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 978 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
We use a dedicated oven we got for free that only gets used for powder coating things and a couple toaster ovens from Goodwill that cost $6 each (for the smaller parts). Maybe this could work for you?
Because of the outgassing from curing the powder coatings, we only use the ovens outside. The oven works great for items like trailing arms, control arms, etc. but, for larger items you can run into problems. We were able to use it on a bar that goes from one side of the 914 to the other that seat belt harnesses attach to, but it required curing half in the oven with some aluminum foil to block heat loss from the partially opened oven door and then turning the bar around to cure the other half. Not ideal. Later came across a YouTube video that showed someone creating an oven from foam board insulation, aluminum tape and a couple Harbor Freight heat guns. This would have worked to cure the seat belt harness bar in one curing step. However, can't find that video right now, but here's a similar one. https://www.tiktok.com/@garage.299/video/7375326760155516193 Again, cure outside and keep an eye on the "foam board insulation oven" just in case the foam can't take the heat. A couple really good features of this type oven is that you can make it different widths or different depths to hold the part you are curing and it can be made to be taken apart so storage takes less space. Haven't tried this yet, but plan to for the next larger piece to be powder coated. |
Lilchopshop Lilchopshop’s Subaru Conversion Project Dec 3 2023, 08:15 PM
Cairo94507 Great; we all love build threads with lots of phot... Dec 4 2023, 10:28 AM
gereed75 Nice work so far. That shift linkage looks really ... Dec 4 2023, 10:47 AM
76-914 Looks great. Will you be able to drop straight dow... Dec 4 2023, 03:39 PM
Lilchopshop
Looks great. Will you be able to drop straight do... Dec 4 2023, 04:32 PM
76-914 Nice looking fab work you have there. Weld the bun... Dec 4 2023, 06:56 PM
tygaboy Do these Subaru engines not benefit from the ol... Dec 4 2023, 07:03 PM
Lilchopshop @76-914 , thanks for the O2 sensor placement advic... Dec 4 2023, 07:50 PM
technicalninja Tygaboy is right!
Every cylinder has an ... Dec 4 2023, 09:07 PM
Lilchopshop
Tygaboy is right!
Every cylinder has an ... Dec 5 2023, 07:48 AM
76-914 You could put 3 into 1 and it will still outperfor... Dec 5 2023, 08:49 AM
76-914 You could put 3 into 1 and it will still outperfor... Dec 5 2023, 08:50 AM
technicalninja 6 cylinder or less should be run through a single ... Dec 5 2023, 10:44 AM
Lilchopshop As I contemplate design changes to my exhaust, I d... Dec 6 2023, 07:48 PM
Lilchopshop I’ve had more distractions lately than I expecte... Jan 27 2024, 11:22 AM
Lilchopshop Couple more pics of the complete exhaust system.
... Jan 27 2024, 11:27 AM
Lilchopshop After finishing the exhaust, I felt like I needed ... Jan 27 2024, 11:39 AM
76-914 Your fabrication work kooks good. Exhaust routing ... Jan 27 2024, 12:15 PM
East coaster Looks good! I just wrapped up my Suby exhaust ... Jan 27 2024, 05:32 PM
Maltese Falcon Buddy of mine in New Mexico is building "Phys... Jan 27 2024, 06:33 PM
Lilchopshop It’s been a while since my last post, but I’ve... Mar 9 2024, 07:54 AM
76-914 It's good that you're back on it. Should b... Mar 9 2024, 08:08 AM
Lilchopshop Well, a year went by since my last post… good th... Mar 13 2025, 04:48 PM
Lilchopshop Next up, I thought I’d start figuring out radiat... Mar 13 2025, 05:40 PM
Cairo94507 Very nice progress. I especially like the new tai... Mar 13 2025, 06:18 PM
FL000 I believe the Subarus run pretty cool (compared to... Mar 13 2025, 07:28 PM
914werke It’s been a while since my last post, but I’v... Mar 13 2025, 08:38 PM
Lilchopshop
It’s been a while since my last post, but I’... Mar 14 2025, 07:50 AM
East coaster I hid mine under a custom center console. Mine is ... Mar 14 2025, 09:18 AM
Lilchopshop
I hid mine under a custom center console. Mine is... Mar 14 2025, 09:35 PM
76-914 You should be able to cool the 2.5 with a much sma... Mar 14 2025, 09:15 PM
Lilchopshop April '25 update:
I've been able to spend... Apr 17 2025, 06:19 AM
East coaster Looking good! Apr 17 2025, 09:16 AM
slowrodent Very very nice work.... :beer2: Apr 17 2025, 10:00 AM
Lilchopshop Well, it’s been a while since my last update her... Jan 21 2026, 05:00 PM
Lilchopshop Enough of that. Here’s the progress on the car... Jan 21 2026, 05:52 PM
Lilchopshop With the radiator and tunnel in place, I mocked up... Jan 21 2026, 06:35 PM
worn Very nice. I see quality in every post. Jan 21 2026, 06:43 PM
tygaboy Lovely bead work! Looks REALLY good. :headban... Jan 21 2026, 07:28 PM
Ninja
With the radiator...
Next up, I’m making the... Jan 21 2026, 08:14 PM
rick 918-S Nice project. That will be very fast! Kent... Jan 22 2026, 06:02 AM
Lilchopshop Thanks guys! Means a lot to me coming from al... Jan 22 2026, 08:56 AM
Lilchopshop Hi All,
Made some more progress over the last few ... Feb 10 2026, 07:20 PM
Lilchopshop The other project I’ve been working on is a 3D p... Feb 10 2026, 07:40 PM
Lilchopshop Been making some progress on the bumper/spoiler/gr... Feb 28 2026, 11:21 AM
Montreal914 Just went through the thread. Very nice custom fab... Feb 28 2026, 11:57 AM
Lilchopshop A little more progress on the bumper/grille/spoile... Mar 6 2026, 05:39 PM
tygaboy Is your printer in your shop or house? I'm pla... Mar 6 2026, 06:36 PM
Lilchopshop
Is your printer in your shop or house? I'm pl... Mar 6 2026, 08:43 PM
tygaboy
[quote name='tygaboy' post='3248091' date='Mar 6 ... Mar 6 2026, 10:21 PM
Lilchopshop Another update. Still working in the frunk. As mu... Mar 22 2026, 07:10 PM
Lilchopshop It’s been a minute since my last update, but the... May 19 2026, 08:53 PM
East coaster Kudos for the creativity! May 20 2026, 03:43 AM
rick 918-S I like the hammer form. May 20 2026, 05:52 AM
Chris H. Very very nice fabrication work. :trophy: May 20 2026, 06:11 AM
Lilchopshop Thanks for the kind words!
The wood buck wo... May 20 2026, 07:42 AM
Lilchopshop It’s all about the journey, right?
So, I’m al... May 28 2026, 07:09 PM
Lilchopshop
We use a dedicated oven we got for free that only... May 29 2026, 05:36 PM
Lilchopshop A couple of little projects before I pull the engi... May 30 2026, 03:29 PM
Lilchopshop Well, it’s been a minute since my last post. I ... Nov 11 2026, 12:30 PM
Lilchopshop Before I close up the driver’s side longitudinal... Nov 11 2026, 01:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th November 2026 - 01:09 PM |
