> Ron's 914, High oil temp
Ron914
post Mar 17 2026, 01:42 PM
Hello all,
It's been about 4 months since I passed my smog test and thought I would be on the way to finally be able to drive my 4 year project .
Well I have been enjoying driving it but only for short trips around town because I feel it has a high oil temperature problem . This is after a short drive around town of 30 minutes . A 45 minute drive will bring the needle on the gauge right to the red zone ,which looking at Phil's calibration photo would indicate about 250F , I don't continue to drive once I get to 250F and pull over and let its cool .
Not exactly sure why or if it really is high ( I don't want to damage my new motor ) but I was given a few things to check by the members hers @Superhawk996 , @emerygt350 .
First I checked my oil Temperature sensor to verify type and operation.
It is a VDO 200 C sensor .
I have the later oil gauge . I removed the sensor and placed it in 212F boiling water and it seems within the correct range on the console gauge .
I am using a Efeng turkey fryer thermometer to check against the gauge in console . The thermometer is accurate . The gauge ( apex seems close to the same reading
There was a discussion the other day on this subject with the question of whether missing a cooling tin on bottom of engine could cause the overheating problem @930cabman .
I have the same issue as I have the tin that the shift rod passes through removed because it the shit rod comes into contact with the tin installed and it shifts better with it removed .
Wondering if I should work on getting it reinstalled to help my cooling ?
I have also worked on the cooling flaps /thermostat but will start a new post for those questions .
I saw a comment about the type of oil . It sounds like Synthetic oil might be a better choice for air cooled oil .
I currently have no oil in my motor and was wondering if Mobil Syn oil would be better than putting back in the Valvoline VR1 20-50W ?
emerygt350
post May 29 2026, 05:12 PM
Did you say your oil temp gauge jumps a quarter way just from turning the key on?
If the ring is not seated correctly it will read way off on the cool side.
Your afr looks fine so far.
How soon after starting the engine were you getting 212 oil on the meat thermometer?
Ron914
post May 29 2026, 05:59 PM
QUOTE(emerygt350 @ May 29 2026, 06:12 PM) *
Hi Dan ,
Yes , as soon as I turn the key on. You can see how much in the first photo where vacuum is zero . This makes me wonder if the gauge is malfunctioning and maybe I do not have a problem .
I assume you're talking about the spark plug ring sensor being loose . This brings up a possible problem .My heads have slightly recessed openings for the plugs so getting the ring correctly seated may be an issue . I really need to put a bit of tongue to the wrench when installing the plug and do not want to strip the threads out so I could try to tighten down a bit more .
Time stamps on the photos show 68 to 212F in approximately 26 minutes . Doesn't seem right to me ?
I have pulled the temperature sender and verified its a VDO 200C sensor and tested it in 212F water while connected to the cars gauge but I cannot find that photo now .
The AFR did look fairly good , probably why I passed my smog test .
Ron914   Ron's 914   Mar 17 2026, 01:42 PM
930cabman   My 2056 build is going on 4 years, basically stock...   Mar 17 2026, 01:50 PM
burton73   Ron, Happy that you completed your smog. I just go...   Mar 17 2026, 02:30 PM
Ron914   Ron, Happy that you completed your smog. I just g...   Mar 17 2026, 03:08 PM
Ron914   @930cabman I too have a new 2056 motor and have b...   Mar 17 2026, 02:56 PM
Superhawk996   Here is a mystery piece of tin that came in a bo...   Mar 17 2026, 03:18 PM
Superhawk996   Regarding the calibration of your gage. That does...   Mar 17 2026, 03:23 PM
Ron914   Regarding the calibration of your gage. That doe...   Mar 17 2026, 04:04 PM
Superhawk996   Based on your post yesterday it sounds like I do...   Mar 17 2026, 07:14 PM
Ishley   At some point you might want to look into an Air f...   Mar 17 2026, 04:37 PM
Montreal914   Separate topic, but do you have a head temperature...   Mar 17 2026, 04:43 PM
mgphoto   I’ve had temps get really crazy hot trying a hig...   Mar 17 2026, 08:42 PM
infraredcalvin   I have one of these, but have never used it so, if...   Mar 17 2026, 10:20 PM
fiacra   …. As for oil, ugh, plenty of opinions on that...   Mar 18 2026, 08:53 AM
Ron914   …. As for oil, ugh, plenty of opinions on tha...   Mar 18 2026, 10:50 AM
fiacra   :headbang: Right...I forgot you had a 49 state ...   Mar 18 2026, 11:18 AM
emerygt350   Can you check to see if that tin is missing? I ca...   Mar 18 2026, 05:59 AM
emerygt350   I wouldn't be afraid of trying 40 weight or le...   Mar 18 2026, 11:22 AM
infraredcalvin   I wouldn't be afraid of trying 40 weight or l...   Mar 18 2026, 12:44 PM
emerygt350   [quote name='emerygt350' post='3249720' date='Mar...   Mar 18 2026, 02:43 PM
sburns1967   In the first picture I do not see the thermostat c...   Mar 18 2026, 01:43 PM
Ron914   Well I finally was able to get my AFR gauge instal...   May 29 2026, 02:10 PM
FlacaProductions   where is your sensor for the CHT gauge? Under #3 p...   May 29 2026, 02:47 PM
FlacaProductions   Dakota Digital instructions to get from C to F dis...   May 29 2026, 02:51 PM
emerygt350   Did you say your oil temp gauge jumps a quarter wa...   May 29 2026, 05:12 PM
Ron914   Did you say your oil temp gauge jumps a quarter w...   May 29 2026, 05:59 PM
emerygt350   Definitely a problem with the line or the gauge or...   May 29 2026, 06:49 PM
Ron914   Definitely a problem with the line or the gauge o...   May 29 2026, 08:19 PM
Ishley   Pull the spark plugs and post a picture. Number ea...   May 29 2026, 07:20 PM
Ron914   Pull the spark plugs and post a picture. Number e...   May 29 2026, 08:00 PM
5 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
1 Members: gonzo54
- Lo-Fi Version Time is now: 29th May 2026 - 09:23 PM
