Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
I finally got around to installing my aux oil cooler. Used a Mocal thermostatic sandwich plate and Derale fan/cooler. Aeroquip blue hose with -8AN push on ends connected it up. Hose runs next to valve cover and zip ties to the wire bales (should make valve adjustments interesting). I removed the heater J tube on the passenger side to route the cooler lines. Since that J tube was just capped anyway, I just removed the J tube and put the cap where the J tube normall attaches to the heat exchangers. So there is no change to the heating system.
Demick Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,254 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
ok, am i nuts? i see the 2 oil lines running right under the stock oil cooler where they exit/enter the sandwich adapter ... (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
