> Guys with original consoles..., is there full carpet underneath?
FlacaProductions
post Jun 6 2026, 01:14 PM
My car did not originally come from the factory with a 3-gauge center console.
PO installed one. I recently swapped that one for a cosmetically better one.
Did cars that came from the factory with a console have a full-length piece of carpet under the console, covering the tunnel and around the shifter just like cars without the console?
FlacaProductions
post Jun 6 2026, 05:15 PM
I think it's original. it is set up like all you had to do is add back the OEM rubber shifter boot and you'd be good to go.
Now, in order to adjust the shifter or replace bushings, etc. you'd have to remove the shift knob, pull up and remove the console panel with leather boot and then you still have a layer of carpet over the shifter.
If you didn't have the console, you could easily pull the center tunnel carpet out and the shifter base is right there.
Seems to me that if you have the console, you wouldn't want/need the carpet under there and I was wondering if there was a different piece for consoles that just went down the outer edges of the tunnel - OR - if it was just covered with the vinyl that is in other places under/around the seats.
wonkipop
post Jun 6 2026, 08:05 PM
QUOTE(FlacaProductions @ Jun 6 2026, 05:15 PM) *
ask @StarBear - his is original 74 with console (appearance group) and had original carpets he recently replaced with NOS stock. pretty sure the carpet piece was in there under the console.
i would have thought the console could be manouvered up over the gear shifter knob.
think it has a hole there big enough?
certainly the original carpet has a hole large enough to get past the shifter knob, but then again is a lot more flexible than wrestling with a console.
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: Ninja
- Lo-Fi Version Time is now: 6th June 2026 - 09:47 PM
