| Freezin 914 |
Jun 7 2026, 06:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 941 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest
Recently assembled new rear shocks, Bilsteins.
100# springs, new rubber parts, stock and new lower perches. I assembled them without springs compressed, and tightened the factory nut assembly (#10 PET) until tight. I believe it is threaded on all the way. Then temporarily slid new rubber bits over the top……my questions are: My donor shocks had some plastic washers under the hats, do I reuse them? Do I need any jounce rubber pieces? (Have never seen them used on any of the cars I have parted, or worked on) Last question, the new nylock nut doesn’t look like it will catch the nylon? Should I use the top nuts I removed from old shocks? I assume the nylon lock nuts would be preferred. Attached image(s)
| bkrantz |
Jun 7 2026, 07:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,716 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Off the top of my head, I think the Bilsteins have inner bounce stops.
| Superhawk996 |
Jun 7 2026, 10:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Off the top of my head, I think the Bilsteins have inner bounce stops. Bilstein yellow sport rear dampers are a monotube design and the “jounce bumper” is inside the tube. [edit: this pertains to the front strut cartridge only] Monotube dampers are a little bit different because they have a floating gas piston inside the damper body that contains the high pressure gas. (Edit addition). I’m now confused myself. I went digging in the Bilstein catalog for p/n 24-001793 to get you a solid reference and it references an internal rebound stop but says nothing about a jounce bumper stop. I can tell you when I assembled mine I didn’t use an external jounce bumper but now I’m doubting myself (IMG:style_emoticons/default/unsure.gif) Install instructions don’t clarify. I may have to contact Bilstein to see what they say. Update: Dear Partners, Dear Customers, Thank you for contacting Bilstein of America. Your inquiry has been received. Your case number is CAS-xxx We will answer your enquiry as soon as possible. Due to the high volume of inquiries, it may take us longer than normal to respond |
Freezin 914 Rear shocks…. Jun 7 2026, 06:16 PM
StarBear Just did mine, the same configuration. No, the jou... Jun 8 2026, 08:04 AM
Superhawk996 @freezin 914
Jun 14 2026, 09:36 PM
L-Jet914 When I replaced my rear shocks with the same Bilst... Jun 14 2026, 11:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 02:50 AM |
