| Superhawk996 |
Jun 7 2026, 04:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
ditch the stat. Cabman - love ya to death but please stop propagating the ditch the thermostat advice. The flaps and thermostat are there for a reason. The majority of engine wear occurs during the warmup phase of operation this is true of all engines and is backed by decades of SAE research and documentation. Disabling flaps and delaying warmup results in accelerated wear. Even worse, air cooled engines depend on expansion of the heads to increase clamp load between the cylinder and the head as the engine heats up. Delaying warmup results in more likelihood of blowby between the head and cylinder and between the cylinder and the case. And even worse yet on a carbureted car where the delayed warmup reduces fuel atomization, and increases cylinder wash down - really accelerating wear and diluting oil. I’ve read all the anecdotal stuff of “my engine is fine”. You may think so but the reality is you are only looking at a tiny snapshot in time of the engine life and wear. As a hobbyist, you likely won’t ever have the opportunity to compare engine life of engine A that ran properly vs engine B that has the flaps disabled. And I’ll concede that because a hobby car only gets driven infrequently - that partially negates the wear argument(s). But let’s not keep propagating the shade tree mindset that the thermostat & flaps aren’t necessary for proper operation and longevity of T4 engines. Once he’s in there deep enough to identify the cause, it should be fixed properly not jury rigged. |
| Superhawk996 |
Jun 8 2026, 07:27 AM
It seems to me that you guys haven’t yet come to terms with how real and how apparent wear is (when measured) as it relates to temperature. In these charts keep in mind this is cylinder temp, not cylinder head temp.
So let’s put up a couple charts on how engine temp affects wear and how much wear occurs when the engine temp is transitioning. This 3rd chart is a GM study that shows ring wear on an already running engine accelerate as the coolant temp and oil sump temperate on a dyno is reduced about 1/2 way through the test. Toward the very end of the test the coolant and sump temperate is again raised and the ring wear levels off / stabilizes. Just to reiterate, I’m not saying the wear is instantaneously going to destroy your engine. However this shadetree mindset that “I haven’t seen” any reduced life is a fallacy. Without a baseline engine that was operated properly for its life to compare against your engine , you’ll never know exactly how much your particular engine life was shortened. As long as you accept that, do what you want. However - advising others to take on that accelerated wear without informing them about the wear trade off isn’t fair to those that might not know any better. |
| JamesM |
Jun 8 2026, 08:50 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,247 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
It seems to me that you guys haven’t yet come to terms with how real and how apparent wear is as it relates to temperature. In these charts keep in mind this is cylinder temp, not cylinder head temp. I'm 100% on board with the wear data, this is the reason I had guys replacing thermostats almost constantly while I was at PMB. Id say roughly one in three was coming in with a broken one. The data points I am adding though (that can also be applied to these charts) is that a "cold start" here at least during the majority of the driving season is generally near if not over 100F+ and that the time to get to 160+ with or without a working thermostat isnt really much different. Assuming at least you are not holding 3k+ rpm immediately after startup. There just isnt enough cooling capacity at idle fan speeds in 100deg ambient (with the asphalt sitting 140-160) to meaningfully slow that process. Air-cooled motors don't have to heat a volume of coolant like a water cooled motor does so this process happens faster and they are not fighting the extra thermal mass due to a broken thermostat in the way water cooled motors do. The regulation of the cooling system on Type 4s is not incredibly accurate to begin with given that there is no thermostat impacted by oil temperature. The only thing regulating oil flow though the cooler is a pressure bypass and the thermostat controlling air flow through the cooler is on the opposite side of the motor from that cooler only getting the airflow off of the 1-2 cylinders. The flaps/thermostat help the system get up to temp quicker in cold weather but the flaps are generally going to be in the full hot position and blowing air over the oil cooler before the oil is up to temp anyways given how much faster the heads and cylinders heat up vs the oil. The wear data is valid, but I don't think even in the best case scenario the type 4s cooling system is fully optimized to take the best advantage of that. |
Superhawk996 To disable cooling flaps or not Jun 7 2026, 04:45 PM
Superhawk996
[quote name='930cabman' post='3260332' date='Jun ... Jun 7 2026, 04:46 PM
Superhawk996
Having results for the OP is the goal, in my opin... Jun 7 2026, 04:47 PM
Superhawk996 @930cabman
Here’s the thing. The defroster pe... Jun 7 2026, 04:55 PM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 7 2026, 06:08 PM
JamesM I think you both have points that are valid to som... Jun 7 2026, 06:48 PM
Superhawk996
BUT given most 914 owners are not driving in cond... Jun 7 2026, 08:09 PM
JamesM
Would anyone here simply take the thermostat out... Jun 7 2026, 11:41 PM
Superhawk996 the 914 thermostat is a lot more impacted by amb... Jun 8 2026, 07:15 AM
era vulgaris
the 914 thermostat is a lot more impacted by am... Jun 8 2026, 08:22 AM
JamesM
I still 100% agree that all of these parts need ... Jun 8 2026, 09:03 AM
Superhawk996
Again though, no one should intentionally remove... Jun 8 2026, 07:16 AM
Superhawk996
Is the consensus his overheating is due to closed... Jun 7 2026, 10:19 PM
emerygt350 It's such a simple and clever device, why not ... Jun 7 2026, 05:04 PM
Jack Standz
To Ron's issue, I was hopeful the tin could b... Jun 7 2026, 07:43 PM
Jack Standz Thermostats were left off 914s and type iv motors ... Jun 8 2026, 02:44 AM
Superhawk996
So, is it better to have an UNSAFE T-stat, a bro... Jun 8 2026, 07:23 AM
JamesM
[quote name='Jack Standz' post='3260436' date='Ju... Jun 8 2026, 07:36 AM
Superhawk996
by failsafe Bug thermostat I assume you are refe... Jun 8 2026, 08:10 AM
Superhawk996 I want to say I appreciate all the civil discussio... Jun 8 2026, 09:49 AM
930cabman
I want to say I appreciate all the civil discussi... Jun 8 2026, 10:15 AM
JamesM
I want to say I appreciate all the civil discussi... Jun 8 2026, 03:48 PM
Superhawk996
It would be cool to have the data, I am a data ... Jun 9 2026, 11:30 AM
JamesM
You may appreciate this data which is represent... Jun 9 2026, 04:00 PM
wonkipop
You may appreciate this data which is represen... Jun 9 2026, 04:23 PM
Superhawk996
wondering if there are things I can implement to ... Jun 9 2026, 06:32 PM
JamesM
wondering if there are things I can implement to... Jun 10 2026, 08:12 AM
Superhawk996 its an interesting problem to think about.
Inde... Jun 10 2026, 12:53 PM
JamesM
Ind... Jun 11 2026, 02:27 PM
Superhawk996
[quote name='Superhawk996' post='3260817' date='J... Jun 11 2026, 05:21 PM
Nogoodwithusernames What does your tune look like? I followed John Con... Jun 11 2026, 11:03 AM
JamesM
What does your tune look like? I followed John Co... Jun 11 2026, 07:19 PM
Jack Standz You must realize that the cylinders in a type iv m... Jun 8 2026, 03:27 PM
porschetub I did a slight mod to the factory mounting bracket... Jun 8 2026, 09:41 PM
emerygt350 Here are some data points on flap activity. Drove... Jun 9 2026, 10:20 AM
Superhawk996
:t... Jun 9 2026, 11:40 AM
JamesM
:... Jun 9 2026, 04:19 PM
Superhawk996
Would be awesome to setup probes to get ambient... Jun 9 2026, 06:29 PM
Superhawk996 doh. Doublepost Jun 9 2026, 06:29 PM
emerygt350 After I loaded my clubs into the car I headed to t... Jun 9 2026, 10:21 AM
JamesM
Notice the cht and the oil temps
This is a 200... Jun 9 2026, 03:48 PM
emerygt350
This is a 20... Jun 9 2026, 03:59 PM
emerygt350 I do have a cheap go pro.... Talk about a movie o... Jun 9 2026, 11:49 AM
emerygt350 Arduinos are cheap and the selection of sensors ar... Jun 9 2026, 07:49 PM
Superhawk996
Arduinos are cheap and the selection of sensors a... Jun 9 2026, 07:55 PM
930cabman Wondering if the boys (girls) in the fatherland we... Jun 11 2026, 11:35 AM
Root_Werks I'm one of those weird people that installed a... Jun 11 2026, 11:56 AM
930cabman
I'm one of those weird people that installed ... Jun 11 2026, 01:19 PM
73-914
I'm one of those weird people that installed ... Jun 12 2026, 11:00 AM
Root_Werks
I'm one of those weird people that installed... Jun 12 2026, 11:10 AM
dr914@autoatlanta.com never Jun 11 2026, 02:47 PM
Jack Standz As has been said before, this is awesome! ... Jun 11 2026, 02:57 PM
emerygt350
As has been said before, this is awesome! ... Jun 11 2026, 05:43 PM
Superhawk996
[quote name='Jack Standz' post='3260973' date='Ju... Jun 12 2026, 06:55 AM
brant Full load redline is the most important for mixtur... Jun 11 2026, 07:34 PM
JamesM Ok, you said I was still on topic so... here goes,... Jun 11 2026, 10:03 PM
emerygt350 Great, now I need a new efi.... Jun 12 2026, 04:19 AM
930cabman Go James Go
I'm sure it's all good stuff,... Jun 12 2026, 04:50 AM
rudedude @jamesm
Would you share your microsquirt tables?.... Jun 12 2026, 07:20 AM
VaccaRabite Late to the conversation.
I have always run with ... Jun 13 2026, 08:40 PM
JamesM
I have always run with... Jun 13 2026, 09:06 PM
emerygt350 I think I may have read somewhere that the lowest ... Jun 14 2026, 05:28 AM
bdstone914 I have never liked the failure prone thermostat an... Jun 14 2026, 01:13 PM
Jack Standz What do you think about a switch triggering electr... Jun 14 2026, 01:39 PM
iankarr Another thing to consider if you're in the ... Jun 14 2026, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:19 AM |
