> To disable cooling flaps or not, The endless debate
Superhawk996
post Jun 7 2026, 04:45 PM
QUOTE(Superhawk996 @ Jun 5 2026, 11:33 AM) *
QUOTE(930cabman @ Jun 5 2026, 11:07 AM) *
ditch the stat.
Cabman - love ya to death but please stop propagating the ditch the thermostat advice.
The flaps and thermostat are there for a reason.
The majority of engine wear occurs during the warmup phase of operation this is true of all engines and is backed by decades of SAE research and documentation.
Disabling flaps and delaying warmup results in accelerated wear.
Even worse, air cooled engines depend on expansion of the heads to increase clamp load between the cylinder and the head as the engine heats up. Delaying warmup results in more likelihood of blowby between the head and cylinder and between the cylinder and the case.
And even worse yet on a carbureted car where the delayed warmup reduces fuel atomization, and increases cylinder wash down - really accelerating wear and diluting oil.
I’ve read all the anecdotal stuff of “my engine is fine”. You may think so but the reality is you are only looking at a tiny snapshot in time of the engine life and wear. As a hobbyist, you likely won’t ever have the opportunity to compare engine life of engine A that ran properly vs engine B that has the flaps disabled.
And I’ll concede that because a hobby car only gets driven infrequently - that partially negates the wear argument(s).
But let’s not keep propagating the shade tree mindset that the thermostat & flaps aren’t necessary for proper operation and longevity of T4 engines.
Once he’s in there deep enough to identify the cause, it should be fixed properly not jury rigged.
Superhawk996
post Jun 7 2026, 04:55 PM
@930cabman
Here’s the thing. The defroster performance has absolutely nothing to do with engine warmup.
The defroster performance is based on the heat exchangers obtaining heat from the engine exhaust heat.
Regardless of the overall engine operating temperature, the exhaust gas exiting the combustion chamber is in excess of 600-800F almost instantaneously.
Just because you have heat doesn’t mean the engine is at operating temperature.
You also keep going back to the analogy of your engine. Engine wear from running cold doesn’t manifest immediately. Unless you have multiple engines that have been run to failure or end of life to compare to a singular data point of your engine at a few thousand miles is practically meaningless.
How many miles on your engine?
I think we both want the same thing for Ron, a functional car to drive.
The thing is for him to disable the flaps, he would still need to drop the engine and resolve what ever is limiting his flap movement and preventing them from getting to full open.
930cabman
post Jun 7 2026, 06:08 PM
QUOTE(Superhawk996 @ Jun 7 2026, 04:55 PM) *
@930cabman
Point made, if I can get it on the list I should probably just get er done. And yes, defrost has little to do with engine temps
To Ron's issue, I was hopeful the tin could be removed in place but I have never attempted this operation. Surely this work is much simpler with the engine on the bench. Is the consensus his overheating is due to closed flaps?
JamesM
post Jun 7 2026, 06:48 PM
I think you both have points that are valid to some extent, but I think context has been left out of the discussion.
Here are some of my thoughts on it:
First I agree that I don't think the Germans put unnecessary parts on the car. That said though they built a car that was intended to be used in ways and across a wide range of environments that I don't think a whole lot of 914 owners actually use them in anymore.
A winter in Germany and a summer in Southern California have different requirements. At this point I think most if not all 914 owners avoid even driving in the rain, let alone sub 20 degrees and snowing.
Why is this relevant? Well, living in Utah and having driven 914s in conditions that are more extreme on both end of the spectrum I have some data points to add. Specifically on a 100 degree day in summer I wont ever see the thermostat closed, but in the winter say cruising down the mountain in 10 degree weather, I wont see it ever open, AND even then its a fight to keep temp in the heads.
So. My personal opinion is that it is BETTER to have the thermostat installed and working, or at least there is not a downside to it because that gives you the best possible outcome under all conditions. BUT given most 914 owners are not driving in conditions that would keep the thermostat closed while driving and that the time it actually spends closed even on startup in hot weather is minimal its probably not the end of the world to go without it. Unless of course you plan on driving down mountain roads in a Utah winter in which case you absolutely want it functioning.
Having the air flaps installed properly though is ALWAYS a must. IDK where anyone got the idea that it was ok to remove the flaps completely but I have seen that done more than a few times.
Superhawk996
post Jun 7 2026, 08:09 PM
QUOTE(JamesM @ Jun 7 2026, 08:48 PM) *
James - I largely agree with your position in a pragmatic sense. Nothing is black and white. The accelerated engine wear isn’t immediately perceptible and will only be evident over the (shortened) life of the motor
However what frustrates the hell out of me is the continued reliance in these threads on one off anecdotal accounts. “My car” or “I saw”.
Here’s the thing. Cold start and warmup wear has been studied extensively by the OEM’s using radiographic techniques to monitor engine component wear during start and warmup operation. There is extensive dyno testing and end of life tear down analysis to know with certainty that not operating in the desired temp range shortens engine life. It just isn’t debatable.
I personally used to attend end of life teardowns, warranty failures, and multiple life (200,000 - 300,000 mile motors) about once a month early in my career. You can defiantly tell the engines that were abused by lack of maintenance, sludged oil, and granny cycle (short trips that never come up to operating temp).
I’ll be happy to start posting some SAE paper numbers going back to the 50’s. But the reality is they are $39/paper to download and I can no longer get them for free at work since I’ve retired.
Would anyone here simply take the thermostat out of your daily driver? I mean after all, if people believe it really doesn’t hurt . . . (IMG:style_emoticons/default/poke.gif) Why have it there to potentially fail. The thermostat on a 914 is no different. The 914 thermostat when operating properly isn’t a binary thing that is just open or closed. The 914 thermostat modulates to keep engine temp in a desired range just like a water pumper thermostat.
And as far as the wholesale removal of the flaps, it seems that at least is well enough understood that we aren’t seeing the complete removal that we used to see in the 80s & 90s.
JamesM
post Jun 7 2026, 11:41 PM
QUOTE(Superhawk996 @ Jun 7 2026, 06:09 PM) *
Having driven both water cooled cars and 914s with failed thermostats there is an observable difference in their temperature control behavior. In my experience when a water cooled thermostat fails the engine never fully comes up to temp, even in the middle of summer. This for sure will cause ongoing accelerated wear, bad gas mileage, etc. In warm weather, I haven't seen that a 914 comes up to temp noticeably slower with a broken thermostat. In the middle of a Utah winter it absolutely does but when thermostats have failed on me in the summer, I don't even notice their failure unless im physically inspecting the engine. the 914 thermostat is a lot more impacted by ambient temperature possibly due to the 914 thermostats placement more or less in ambient air. Yes they modulate temperature but the range in which this modulation occurs only seems to exist at colder ambient temps.
Again though, no one should intentionally remove a working thermostat, it accomplishes nothing positive. I'm just saying if your thermostat fails in the middle of summer it probably isnt reason to stop driving your 914 until you can source a replacement. Given its going to take most people 20 years to put 100k on their 914s these days and things like carb conversions, worn out d-jet setups, cylinder cooling fins that have never been cleaned, missing engine tin grommets, etc are contributing far more to engine internal wear than an extra 60 seconds of warm up time.
Superhawk996
post Jun 8 2026, 07:15 AM
QUOTE(JamesM @ Jun 8 2026, 01:41 AM) *
Here’s the thing - what you observe while the car is sitting static isn’t the same as what’s going on while driving.
Because the bellows is largely in the ambient air steam it is getting much cooler airflow while driving (partially closing flaps) than when you see it while then vehicle is sitting static and only getting hot engine air from above.
Sure on a 100+ day - once warned it won’t modulate much. However, don’t overestimate the number of cars being driven in 100F + temps especially those without A/C.
era vulgaris
post Jun 8 2026, 08:22 AM
J is for Genius
QUOTE(Superhawk996 @ Jun 8 2026, 09:15 AM) *
But, it's not actually supposed to be in the ambient air stream. On ACVW's it's protected from the ambient air stream by the sled tins, and on 914's it's protected from the ambient air stream by the lower engine tin (the angular looking one with the half-cylindrical indent for the shift rod). However since these lower tins are missing from most 914's, the thermostat ends up in ambient air where it really was never meant to be.
I still 100% agree that all of these parts need to be there (just got in this same discussion recently on the samba because alot of people don't understand how critical a fast engine warm up is), but if you want the system working exactly as it should, that lower engine tin also needs to be in place.
JamesM
post Jun 8 2026, 09:03 AM
QUOTE(era vulgaris @ Jun 8 2026, 06:22 AM) *
I agree here as well. It is one of the points that has always bothered me about running headers on a type 4 is that you loose the lower tin.
After owning a water cooled Vangon for some time though I made an interesting observation. Vanagons also have a lower tin below the pushrod tubes despite having fully jacketed cylinders/no cooling air flow coming down off the heads/cylinders. In that application at least its only purpose is to protect the pushrod tubes.
I cant say what the engineers specifically designed that tin for on the type 4 but its something to think about.
Superhawk996   To disable cooling flaps or not   Jun 7 2026, 04:45 PM
Superhawk996   [quote name='930cabman' post='3260332' date='Jun ...   Jun 7 2026, 04:46 PM
Superhawk996   Having results for the OP is the goal, in my opin...   Jun 7 2026, 04:47 PM
Superhawk996   @930cabman Here’s the thing. The defroster pe...   Jun 7 2026, 04:55 PM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 7 2026, 06:08 PM
JamesM   I think you both have points that are valid to som...   Jun 7 2026, 06:48 PM
Superhawk996   BUT given most 914 owners are not driving in cond...   Jun 7 2026, 08:09 PM
JamesM   Would anyone here simply take the thermostat out...   Jun 7 2026, 11:41 PM
Superhawk996   the 914 thermostat is a lot more impacted by amb...   Jun 8 2026, 07:15 AM
era vulgaris   the 914 thermostat is a lot more impacted by am...   Jun 8 2026, 08:22 AM
JamesM   I still 100% agree that all of these parts need ...   Jun 8 2026, 09:03 AM
Superhawk996   Again though, no one should intentionally remove...   Jun 8 2026, 07:16 AM
Superhawk996   Is the consensus his overheating is due to closed...   Jun 7 2026, 10:19 PM
emerygt350   It's such a simple and clever device, why not ...   Jun 7 2026, 05:04 PM
Jack Standz   To Ron's issue, I was hopeful the tin could b...   Jun 7 2026, 07:43 PM
Jack Standz   Thermostats were left off 914s and type iv motors ...   Jun 8 2026, 02:44 AM
Superhawk996   So, is it better to have an UNSAFE T-stat, a bro...   Jun 8 2026, 07:23 AM
JamesM   [quote name='Jack Standz' post='3260436' date='Ju...   Jun 8 2026, 07:36 AM
Superhawk996   by failsafe Bug thermostat I assume you are refe...   Jun 8 2026, 08:10 AM
Superhawk996   It seems to me that you guys haven’t yet come to...   Jun 8 2026, 07:27 AM
JamesM   It seems to me that you guys haven’t yet come t...   Jun 8 2026, 08:50 AM
Superhawk996   I want to say I appreciate all the civil discussio...   Jun 8 2026, 09:49 AM
930cabman   I want to say I appreciate all the civil discussi...   Jun 8 2026, 10:15 AM
JamesM   I want to say I appreciate all the civil discussi...   Jun 8 2026, 03:48 PM
Superhawk996   It would be cool to have the data, I am a data ...   Jun 9 2026, 11:30 AM
JamesM   You may appreciate this data which is represent...   Jun 9 2026, 04:00 PM
wonkipop   You may appreciate this data which is represen...   Jun 9 2026, 04:23 PM
Superhawk996   wondering if there are things I can implement to ...   Jun 9 2026, 06:32 PM
JamesM   wondering if there are things I can implement to...   Jun 10 2026, 08:12 AM
Superhawk996   its an interesting problem to think about. Inde...   Jun 10 2026, 12:53 PM
JamesM   its an interesting problem to think about. Ind...   Jun 11 2026, 02:27 PM
Superhawk996   [quote name='Superhawk996' post='3260817' date='J...   Jun 11 2026, 05:21 PM
Nogoodwithusernames   What does your tune look like? I followed John Con...   Jun 11 2026, 11:03 AM
JamesM   What does your tune look like? I followed John Co...   Jun 11 2026, 07:19 PM
Jack Standz   You must realize that the cylinders in a type iv m...   Jun 8 2026, 03:27 PM
porschetub   I did a slight mod to the factory mounting bracket...   Jun 8 2026, 09:41 PM
emerygt350   Here are some data points on flap activity. Drove...   Jun 9 2026, 10:20 AM
Superhawk996   Here are some data points on flap activity. :t...   Jun 9 2026, 11:40 AM
JamesM   Here are some data points on flap activity. :...   Jun 9 2026, 04:19 PM
Superhawk996   Would be awesome to setup probes to get ambient...   Jun 9 2026, 06:29 PM
Superhawk996   doh. Doublepost   Jun 9 2026, 06:29 PM
emerygt350   After I loaded my clubs into the car I headed to t...   Jun 9 2026, 10:21 AM
JamesM   Notice the cht and the oil temps This is a 200...   Jun 9 2026, 03:48 PM
emerygt350   Notice the cht and the oil temps This is a 20...   Jun 9 2026, 03:59 PM
emerygt350   I do have a cheap go pro.... Talk about a movie o...   Jun 9 2026, 11:49 AM
emerygt350   Arduinos are cheap and the selection of sensors ar...   Jun 9 2026, 07:49 PM
Superhawk996   Arduinos are cheap and the selection of sensors a...   Jun 9 2026, 07:55 PM
930cabman   Wondering if the boys (girls) in the fatherland we...   Jun 11 2026, 11:35 AM
Root_Werks   I'm one of those weird people that installed a...   Jun 11 2026, 11:56 AM
930cabman   I'm one of those weird people that installed ...   Jun 11 2026, 01:19 PM
73-914   I'm one of those weird people that installed ...   Jun 12 2026, 11:00 AM
Root_Werks   I'm one of those weird people that installed...   Jun 12 2026, 11:10 AM
dr914@autoatlanta.com   never   Jun 11 2026, 02:47 PM
Jack Standz   As has been said before, this is awesome! ...   Jun 11 2026, 02:57 PM
emerygt350   As has been said before, this is awesome! ...   Jun 11 2026, 05:43 PM
Superhawk996   [quote name='Jack Standz' post='3260973' date='Ju...   Jun 12 2026, 06:55 AM
brant   Full load redline is the most important for mixtur...   Jun 11 2026, 07:34 PM
JamesM   Ok, you said I was still on topic so... here goes,...   Jun 11 2026, 10:03 PM
emerygt350   Great, now I need a new efi....   Jun 12 2026, 04:19 AM
930cabman   Go James Go I'm sure it's all good stuff,...   Jun 12 2026, 04:50 AM
rudedude   @jamesm Would you share your microsquirt tables?....   Jun 12 2026, 07:20 AM
VaccaRabite   Late to the conversation. I have always run with ...   Jun 13 2026, 08:40 PM
JamesM   Late to the conversation. I have always run with...   Jun 13 2026, 09:06 PM
emerygt350   I think I may have read somewhere that the lowest ...   Jun 14 2026, 05:28 AM
bdstone914   I have never liked the failure prone thermostat an...   Jun 14 2026, 01:13 PM
Jack Standz   What do you think about a switch triggering electr...   Jun 14 2026, 01:39 PM
iankarr   Another thing to consider if you're in the ...   Jun 14 2026, 07:45 PM
- Lo-Fi Version Time is now: 15th June 2026 - 02:53 AM
