> 2 hour oil cooler install, Preparations for WCC
Demick
post Feb 13 2005, 09:41 PM
Ernie made me do it!
I finally got around to installing my aux oil cooler. Used a Mocal thermostatic sandwich plate and Derale fan/cooler. Aeroquip blue hose with -8AN push on ends connected it up. Hose runs next to valve cover and zip ties to the wire bales (should make valve adjustments interesting). I removed the heater J tube on the passenger side to route the cooler lines. Since that J tube was just capped anyway, I just removed the J tube and put the cap where the J tube normall attaches to the heat exchangers. So there is no change to the heating system.
Demick
Aaron Cox
post Feb 14 2005, 12:14 AM
Professional Lawn Dart
way cool demick!
where did you order the parts from?
i think i can get away with running a fluidyne thinline (used) cooler up front and all fittings and lines for less than 300..... wonder how much oil that adds? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Demick   2 hour oil cooler install   Feb 13 2005, 09:41 PM
Demick   And here is the sandwich adapter showing oil line ...   Feb 13 2005, 09:42 PM
Demick   more   Feb 13 2005, 09:43 PM
SirAndy     Feb 13 2005, 10:01 PM
Demick   Air does not blow onto the cooler lines. There is...   Feb 13 2005, 10:07 PM
SirAndy     Feb 13 2005, 10:09 PM
Aaron Cox   <...   Feb 13 2005, 10:11 PM
SirAndy     Feb 13 2005, 10:11 PM
trekkor     Feb 13 2005, 10:23 PM
Aaron Cox   BTW: how much was the sandwhich adapter and pricer...   Feb 13 2005, 10:33 PM
Demick   Andy - you are right - the lines run under the sto...   Feb 13 2005, 10:50 PM
tommy914   Demick, I have a similar setup and have been happ...   Feb 13 2005, 11:12 PM
J P Stein   I'm gonna use that blue hose for fuel lines. I...   Feb 13 2005, 11:23 PM
tommy914   My Aeroquip guy said NO hose clamps. The barbs on...   Feb 13 2005, 11:27 PM
Joseph Mills     Feb 14 2005, 12:00 AM
McMark   There's the best way and then there's good...   Feb 14 2005, 12:04 AM
Demick   Tommy: Yes, I considered running the hoses throug...   Feb 14 2005, 12:07 AM
bernbomb914   I installed a cooler like yours but I put it close...   Feb 14 2005, 03:09 AM
Triaddave   i got the same cooler/fan last friday. i was plann...   Feb 14 2005, 11:43 AM
cha914   Aaron, I ran my cooler up front using the blue ho...   Feb 14 2005, 12:53 PM
Demick   Well, today was the first day in a week and a half...   Feb 23 2005, 10:19 AM
AZ914   Demick, Congrats!! http://www.914w...   Feb 23 2005, 02:57 PM
Aaron Cox   <...   Feb 23 2005, 02:59 PM
AZ914   Aaron, If you figure something out with the valan...   Feb 23 2005, 04:25 PM
kenpolives   I've got a similar set up on order for air coo...   Feb 24 2005, 04:51 AM
Demick
- Lo-Fi Version Time is now: 8th July 2025 - 08:42 PM
