| morehills |
Jun 10 2026, 07:47 AM
Member ![]() ![]() Group: Members Posts: 141 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States
I'm finishing up new vinyl install and I'm having trouble with the sail trim attachment (PO had it glued in place). Does the clip face rearward? Also, the clip seem too narrow to engage both sides of the channel in the underside of the trim piece. Is this normal or is the clip simply too small? Thank you, John
| Cairo94507 |
Jun 10 2026, 08:45 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,666 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
If I recall right, you need to rotate the clip 90 degrees and it will slide into the trim piece and you attach the nut from inside the fender well. You could use some dum-dum on the trim piece to keep the clip from being loose in the trim. (IMG:style_emoticons/default/beerchug.gif)
morehills Help attaching sail panel trim Jun 10 2026, 07:47 AM
mepstein I haven't attached one in years but I thought ... Jun 10 2026, 08:37 AM
rudedude I found it seemed to fit better with the raised ar... Jun 10 2026, 09:14 AM
morehills Yes, I made it work with the lip pointed back towa... Jun 10 2026, 11:04 AM
porschetub Hi nice work ,i remember adjusting the door window... Jun 10 2026, 05:31 PM
morehills Yes, getting the nut on near the oil tank was a be... Jun 10 2026, 07:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 10:30 PM |
