| morehills |
Jun 10 2026, 07:47 AM
Member ![]() ![]() Group: Members Posts: 141 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States
I'm finishing up new vinyl install and I'm having trouble with the sail trim attachment (PO had it glued in place). Does the clip face rearward? Also, the clip seem too narrow to engage both sides of the channel in the underside of the trim piece. Is this normal or is the clip simply too small? Thank you, John
| rudedude |
Jun 10 2026, 09:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 566 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
I found it seemed to fit better with the raised area to the middle. And yes it took quite a bit of fiddling with the lower new Porsche trim piece to get it close to fitting. The original still fit perfect but all sc ratchet up so I didn’t use them
morehills Help attaching sail panel trim Jun 10 2026, 07:47 AM
mepstein I haven't attached one in years but I thought ... Jun 10 2026, 08:37 AM
Cairo94507 If I recall right, you need to rotate the clip 90 ... Jun 10 2026, 08:45 AM
morehills Yes, I made it work with the lip pointed back towa... Jun 10 2026, 11:04 AM
porschetub Hi nice work ,i remember adjusting the door window... Jun 10 2026, 05:31 PM
morehills Yes, getting the nut on near the oil tank was a be... Jun 10 2026, 07:19 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th June 2026 - 10:30 PM |
