> Help attaching sail panel trim
morehills
post Jun 10 2026, 07:47 AM
I'm finishing up new vinyl install and I'm having trouble with the sail trim attachment (PO had it glued in place). Does the clip face rearward? Also, the clip seem too narrow to engage both sides of the channel in the underside of the trim piece. Is this normal or is the clip simply too small? Thank you, John
porschetub
post Jun 10 2026, 05:31 PM
Hi nice work ,i remember adjusting the door window end of the lower trim ,if you are careful doing that you don't damage the anodizing @ that end .
How did you go getting the nut and washer on the bracket above the oil tank ,I found it a bit of a challenge with my factory tank in the way and had to do it by "feel" and finally got there .
Common sense would have been better on my part as I should have fitted this with the tank out but was keen to get it driving after the build.
Cheers.
- Lo-Fi Version Time is now: 10th June 2026 - 10:29 PM
