| Superhawk996 |
Jun 7 2026, 04:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
ditch the stat. Cabman - love ya to death but please stop propagating the ditch the thermostat advice. The flaps and thermostat are there for a reason. The majority of engine wear occurs during the warmup phase of operation this is true of all engines and is backed by decades of SAE research and documentation. Disabling flaps and delaying warmup results in accelerated wear. Even worse, air cooled engines depend on expansion of the heads to increase clamp load between the cylinder and the head as the engine heats up. Delaying warmup results in more likelihood of blowby between the head and cylinder and between the cylinder and the case. And even worse yet on a carbureted car where the delayed warmup reduces fuel atomization, and increases cylinder wash down - really accelerating wear and diluting oil. I’ve read all the anecdotal stuff of “my engine is fine”. You may think so but the reality is you are only looking at a tiny snapshot in time of the engine life and wear. As a hobbyist, you likely won’t ever have the opportunity to compare engine life of engine A that ran properly vs engine B that has the flaps disabled. And I’ll concede that because a hobby car only gets driven infrequently - that partially negates the wear argument(s). But let’s not keep propagating the shade tree mindset that the thermostat & flaps aren’t necessary for proper operation and longevity of T4 engines. Once he’s in there deep enough to identify the cause, it should be fixed properly not jury rigged. |
| Superhawk996 |
Jun 8 2026, 09:49 AM
I want to say I appreciate all the civil discussion on this topic.
Unfortunately we’ve sort of reached the point where someone needs to do some instrumented testing to get us out of the realm of speculation on the degree that the flaps are modulating and when. I’m guilty here as I don’t have that data at hand. Someday I’d love to put a string-pot on the thermostat bellows and the flap rod/lever to get live data on how much it’s moving, at what temps, and what engine loads. Same for having some thermocouple data directly off the cylinders and the bellows. Ah . . . Someday. For now I’ve got too many other projects going on but maybe someday. |
| JamesM |
Jun 8 2026, 03:48 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,247 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I want to say I appreciate all the civil discussion on this topic. Unfortunately we’ve sort of reached the point where someone needs to do some instrumented testing to get us out of the realm of speculation on the degree that the flaps are modulating and when. I’m guilty here as I don’t have that data at hand. Someday I’d love to put a string-pot on the thermostat bellows and the flap rod/lever to get live data on how much it’s moving, at what temps, and what engine loads. Same for having some thermocouple data directly off the cylinders and the bellows. Ah . . . Someday. For now I’ve got too many other projects going on but maybe someday. FYI awesome powder coat lists the temp of their various thermostats however I am not sure if that temp is the temp where they start to expand, finish expanding or if the 85-90c they list is the range for the start and finish of the expansion? (IMG:style_emoticons/default/confused24.gif) that says nothing of the actual curve and impact of it on the actual angle of the cooling flaps or how it compares to the actual head and oil temps One could deduce though that given the 85c(185f) listed thermostat temp that VW intended the motor to be warmer than the 160f accelerated wear point mentioned in the studies you posted. It would be cool to have the data, I am a data junkie as well. A huge timesaver though would be to just leave the thermostats hooked up and let them do their thing. (IMG:style_emoticons/default/biggrin.gif) |
| Superhawk996 |
Jun 9 2026, 11:30 AM
It would be cool to have the data, I am a data junkie as well. A huge timesaver though would be to just leave the thermostats hooked up and let them do their thing. (IMG:style_emoticons/default/biggrin.gif) You may appreciate this data which is representative of your situation in the mountains. From Air Cooled Automotive Engines; J. Mackerle The important point to note is that you don’t really want cylinder temp going below 70C and how the thermostat prevents that from happening on the decent. Also note that temp consistency is improved. Higher, more consistent temp = less friction losses. |
| JamesM |
Jun 9 2026, 04:00 PM
You may appreciate this data which is representative of your situation in the mountains. That's a great find and does reflect what I have experienced. I wonder what motor/induction was used here. This all has me thinking about ways to utilizing tuning on modern ECUs to better regulate temperatures. This is something I have implemented to some extent but only focusing on keeping temperatures down. Now im wondering if there are things I can implement to increase temps under cold decel situations as it looks like even with the flaps the cooling is pretty pronounced. |
| Superhawk996 |
Jun 9 2026, 06:32 PM
wondering if there are things I can implement to increase temps under cold decel situations as it looks like even with the flaps the cooling is pretty pronounced. I would think you could get something by running a lean burn and advance timing short of decel fuel shutoff that might help but may be difficult to tune without knock sensors. That data that I posted is ancient - that book was 1st published in 60’s so I would almost guarantee that was a carbureted engine. |
| JamesM |
Jun 10 2026, 08:12 AM
wondering if there are things I can implement to increase temps under cold decel situations as it looks like even with the flaps the cooling is pretty pronounced. I would think you could get something by running a lean burn and advance timing short of decel fuel shutoff that might help but may be difficult to tune without knock sensors. That data that I posted is ancient - that book was 1st published in 60’s so I would almost guarantee that was a carbureted engine. Lean burn with advanced timing is how my heads are running 75 deg cooler than stock at cruise as it is (IMG:style_emoticons/default/biggrin.gif) Head temps drop off quicker on the lean side of stoich than they do on the rich side. Added bonus I get near 40mpg and my oil stays way cleaner too, which itself should be better for engine wear. Around stoich is the hottest but limiting that to only during conditions where you are experiencing extreme cooling would be the challenge. Driving down a mountain in freezing weather is a bit of an edge case for me given they salt the roads here in winter so for now ill take the trade off, but its an interesting problem to think about. ![]() |
| Nogoodwithusernames |
Jun 11 2026, 11:03 AM
Member ![]() ![]() Group: Members Posts: 307 Joined: 31-May 16 From: Sutter, CA Member No.: 20,051 Region Association: None |
What does your tune look like? I followed John Connolly's advice/thread over on the Samba for trying to tune my Megasquirted 1.7 T4 (In my Squarback) for lean cruise and could never get head temps down under 350F, running 12.x at cruise now and heads are 320-340F at 60-70MPH. Varies a bit with ambient temp. I only get 19-21mpg with mixed driving though.
I do run a stock working Tstat in both the 914 and the Squareback, with all tins (including custom sled tins to keep it out of ambient airstream on the VW), but I've never checked position at various loads or temperatures on either so I don't have much to add in that regard. I will say I don't drive the 914 when it's 90+ outside because that's miserable without AC, much preferable when it's 60-70F outside. wondering if there are things I can implement to increase temps under cold decel situations as it looks like even with the flaps the cooling is pretty pronounced. I would think you could get something by running a lean burn and advance timing short of decel fuel shutoff that might help but may be difficult to tune without knock sensors. That data that I posted is ancient - that book was 1st published in 60’s so I would almost guarantee that was a carbureted engine. Lean burn with advanced timing is how my heads are running 75 deg cooler than stock at cruise as it is (IMG:style_emoticons/default/biggrin.gif) Head temps drop off quicker on the lean side of stoich than they do on the rich side. Added bonus I get near 40mpg and my oil stays way cleaner too, which itself should be better for engine wear. Around stoich is the hottest but limiting that to only during conditions where you are experiencing extreme cooling would be the challenge. Driving down a mountain in freezing weather is a bit of an edge case for me given they salt the roads here in winter so for now ill take the trade off, but its an interesting problem to think about. ![]() |
Superhawk996 To disable cooling flaps or not Jun 7 2026, 04:45 PM
Superhawk996
[quote name='930cabman' post='3260332' date='Jun ... Jun 7 2026, 04:46 PM
Superhawk996
Having results for the OP is the goal, in my opin... Jun 7 2026, 04:47 PM
Superhawk996 @930cabman
Here’s the thing. The defroster pe... Jun 7 2026, 04:55 PM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 7 2026, 06:08 PM
JamesM I think you both have points that are valid to som... Jun 7 2026, 06:48 PM
Superhawk996
BUT given most 914 owners are not driving in cond... Jun 7 2026, 08:09 PM
JamesM
Would anyone here simply take the thermostat out... Jun 7 2026, 11:41 PM
Superhawk996 the 914 thermostat is a lot more impacted by amb... Jun 8 2026, 07:15 AM
era vulgaris
the 914 thermostat is a lot more impacted by am... Jun 8 2026, 08:22 AM
JamesM
I still 100% agree that all of these parts need ... Jun 8 2026, 09:03 AM
Superhawk996
Again though, no one should intentionally remove... Jun 8 2026, 07:16 AM
Superhawk996
Is the consensus his overheating is due to closed... Jun 7 2026, 10:19 PM
emerygt350 It's such a simple and clever device, why not ... Jun 7 2026, 05:04 PM
Jack Standz
To Ron's issue, I was hopeful the tin could b... Jun 7 2026, 07:43 PM
Jack Standz Thermostats were left off 914s and type iv motors ... Jun 8 2026, 02:44 AM
Superhawk996
So, is it better to have an UNSAFE T-stat, a bro... Jun 8 2026, 07:23 AM
JamesM
[quote name='Jack Standz' post='3260436' date='Ju... Jun 8 2026, 07:36 AM
Superhawk996
by failsafe Bug thermostat I assume you are refe... Jun 8 2026, 08:10 AM
Superhawk996 It seems to me that you guys haven’t yet come to... Jun 8 2026, 07:27 AM
JamesM
It seems to me that you guys haven’t yet come t... Jun 8 2026, 08:50 AM
930cabman
I want to say I appreciate all the civil discussi... Jun 8 2026, 10:15 AM
wonkipop
You may appreciate this data which is represen... Jun 9 2026, 04:23 PM
Superhawk996 its an interesting problem to think about.
Inde... Jun 10 2026, 12:53 PM
JamesM
Ind... Jun 11 2026, 02:27 PM
Superhawk996
[quote name='Superhawk996' post='3260817' date='J... Jun 11 2026, 05:21 PM
JamesM
What does your tune look like? I followed John Co... Jun 11 2026, 07:19 PM
Jack Standz You must realize that the cylinders in a type iv m... Jun 8 2026, 03:27 PM
porschetub I did a slight mod to the factory mounting bracket... Jun 8 2026, 09:41 PM
emerygt350 Here are some data points on flap activity. Drove... Jun 9 2026, 10:20 AM
Superhawk996
:t... Jun 9 2026, 11:40 AM
JamesM
:... Jun 9 2026, 04:19 PM
Superhawk996
Would be awesome to setup probes to get ambient... Jun 9 2026, 06:29 PM
Superhawk996 doh. Doublepost Jun 9 2026, 06:29 PM
emerygt350 After I loaded my clubs into the car I headed to t... Jun 9 2026, 10:21 AM
JamesM
Notice the cht and the oil temps
This is a 200... Jun 9 2026, 03:48 PM
emerygt350
This is a 20... Jun 9 2026, 03:59 PM
emerygt350 I do have a cheap go pro.... Talk about a movie o... Jun 9 2026, 11:49 AM
emerygt350 Arduinos are cheap and the selection of sensors ar... Jun 9 2026, 07:49 PM
Superhawk996
Arduinos are cheap and the selection of sensors a... Jun 9 2026, 07:55 PM
930cabman Wondering if the boys (girls) in the fatherland we... Jun 11 2026, 11:35 AM
Root_Werks I'm one of those weird people that installed a... Jun 11 2026, 11:56 AM
930cabman
I'm one of those weird people that installed ... Jun 11 2026, 01:19 PM
73-914
I'm one of those weird people that installed ... Jun 12 2026, 11:00 AM
Root_Werks
I'm one of those weird people that installed... Jun 12 2026, 11:10 AM
dr914@autoatlanta.com never Jun 11 2026, 02:47 PM
Jack Standz As has been said before, this is awesome! ... Jun 11 2026, 02:57 PM
emerygt350
As has been said before, this is awesome! ... Jun 11 2026, 05:43 PM
Superhawk996
[quote name='Jack Standz' post='3260973' date='Ju... Jun 12 2026, 06:55 AM
brant Full load redline is the most important for mixtur... Jun 11 2026, 07:34 PM
JamesM Ok, you said I was still on topic so... here goes,... Jun 11 2026, 10:03 PM
emerygt350 Great, now I need a new efi.... Jun 12 2026, 04:19 AM
930cabman Go James Go
I'm sure it's all good stuff,... Jun 12 2026, 04:50 AM
rudedude @jamesm
Would you share your microsquirt tables?.... Jun 12 2026, 07:20 AM
VaccaRabite Late to the conversation.
I have always run with ... Jun 13 2026, 08:40 PM
JamesM
I have always run with... Jun 13 2026, 09:06 PM
emerygt350 I think I may have read somewhere that the lowest ... Jun 14 2026, 05:28 AM
bdstone914 I have never liked the failure prone thermostat an... Jun 14 2026, 01:13 PM
Jack Standz What do you think about a switch triggering electr... Jun 14 2026, 01:39 PM
iankarr Another thing to consider if you're in the ... Jun 14 2026, 07:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:26 AM |
