| young55961 |
Jun 16 2026, 04:19 PM
Newbie ![]() Group: Members Posts: 28 Joined: 15-March 18 From: Arcadia Member No.: 21,972 Region Association: Southern California |
I am currently stuck while installing the intake runners onto the cylinder heads.
My engine number starts with "GC," so I believe it is a 2.0L engine. However, the cylinder heads have a 4-bolt intake pattern. I suspect a previous owner may have swapped the cylinder heads when converting the engine to dual carburetors. Can I simply look for 4-bolt intake runners to match these heads, or is there an adapter available that would allow me to use the 2.0L intake runners? From what I have seen, the original 3-bolt 2.0L cylinder heads are rare and expensive. Has anyone run into this situation before? Any suggestions would be appreciated. Thanks, Billy |
| Jack Standz |
Jun 16 2026, 05:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 834 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
One more thing. If you originally had a 2 liter motor and have replaced it with a motor with 4 stud cylinder heads, where are your spark plugs located?
Lots of 4 stud cylinder heads have the 1.7/1.8 spark plug hole locations that are in a different location than the 2 liter cylinder heads. If this is the case, it will affect performance and you will need the correct tin. |
young55961 Convert back to D Jet Fuel Injection- Jun 16 2026, 04:19 PM
Jack Standz
Can I simply look for 4-bolt intake runners to m... Jun 16 2026, 05:04 PM
young55961
Can I simply look for 4-bolt intake runners to ... Jun 16 2026, 05:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th June 2026 - 07:49 PM |
