| Superhawk996 |
Jun 7 2026, 04:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
ditch the stat. Cabman - love ya to death but please stop propagating the ditch the thermostat advice. The flaps and thermostat are there for a reason. The majority of engine wear occurs during the warmup phase of operation this is true of all engines and is backed by decades of SAE research and documentation. Disabling flaps and delaying warmup results in accelerated wear. Even worse, air cooled engines depend on expansion of the heads to increase clamp load between the cylinder and the head as the engine heats up. Delaying warmup results in more likelihood of blowby between the head and cylinder and between the cylinder and the case. And even worse yet on a carbureted car where the delayed warmup reduces fuel atomization, and increases cylinder wash down - really accelerating wear and diluting oil. I’ve read all the anecdotal stuff of “my engine is fine”. You may think so but the reality is you are only looking at a tiny snapshot in time of the engine life and wear. As a hobbyist, you likely won’t ever have the opportunity to compare engine life of engine A that ran properly vs engine B that has the flaps disabled. And I’ll concede that because a hobby car only gets driven infrequently - that partially negates the wear argument(s). But let’s not keep propagating the shade tree mindset that the thermostat & flaps aren’t necessary for proper operation and longevity of T4 engines. Once he’s in there deep enough to identify the cause, it should be fixed properly not jury rigged. |
| frank_c |
Jun 15 2026, 10:19 PM
Member ![]() ![]() Group: Members Posts: 95 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
Do folks have any insight as to why the air-cooled sixes don't have a similar mechanism to the T4 for thermostatically controlled cooling airflow?
I remember seeing this question asked in some other thread or forum, but don't recall if it was ever answered (or I just forgot (IMG:style_emoticons/default/sad.gif) ). |
| Krieger |
Jun 17 2026, 09:35 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,863 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Do folks have any insight as to why the air-cooled sixes don't have a similar mechanism to the T4 for thermostatically controlled cooling airflow? I remember seeing this question asked in some other thread or forum, but don't recall if it was ever answered (or I just forgot (IMG:style_emoticons/default/sad.gif) ). The 911 has all aluminum case, cylinder and heads. Type 4 has cast iron cylinders. Expansion rates are different. This is a factor. |
Superhawk996 To disable cooling flaps or not Jun 7 2026, 04:45 PM
Superhawk996
[quote name='930cabman' post='3260332' date='Jun ... Jun 7 2026, 04:46 PM
Superhawk996
Having results for the OP is the goal, in my opin... Jun 7 2026, 04:47 PM
Superhawk996 @930cabman
Here’s the thing. The defroster pe... Jun 7 2026, 04:55 PM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 7 2026, 06:08 PM
JamesM I think you both have points that are valid to som... Jun 7 2026, 06:48 PM
Superhawk996
BUT given most 914 owners are not driving in cond... Jun 7 2026, 08:09 PM
JamesM
Would anyone here simply take the thermostat out... Jun 7 2026, 11:41 PM
Superhawk996 the 914 thermostat is a lot more impacted by amb... Jun 8 2026, 07:15 AM
era vulgaris
the 914 thermostat is a lot more impacted by am... Jun 8 2026, 08:22 AM
JamesM
I still 100% agree that all of these parts need ... Jun 8 2026, 09:03 AM
Superhawk996
Again though, no one should intentionally remove... Jun 8 2026, 07:16 AM
Superhawk996
Is the consensus his overheating is due to closed... Jun 7 2026, 10:19 PM
emerygt350 It's such a simple and clever device, why not ... Jun 7 2026, 05:04 PM
Jack Standz
To Ron's issue, I was hopeful the tin could b... Jun 7 2026, 07:43 PM
Jack Standz Thermostats were left off 914s and type iv motors ... Jun 8 2026, 02:44 AM
Superhawk996
So, is it better to have an UNSAFE T-stat, a bro... Jun 8 2026, 07:23 AM
JamesM
[quote name='Jack Standz' post='3260436' date='Ju... Jun 8 2026, 07:36 AM
Superhawk996
by failsafe Bug thermostat I assume you are refe... Jun 8 2026, 08:10 AM
Superhawk996 It seems to me that you guys haven’t yet come to... Jun 8 2026, 07:27 AM
JamesM
It seems to me that you guys haven’t yet come t... Jun 8 2026, 08:50 AM
Superhawk996 I want to say I appreciate all the civil discussio... Jun 8 2026, 09:49 AM
930cabman
I want to say I appreciate all the civil discussi... Jun 8 2026, 10:15 AM
JamesM
I want to say I appreciate all the civil discussi... Jun 8 2026, 03:48 PM
Superhawk996
It would be cool to have the data, I am a data ... Jun 9 2026, 11:30 AM
JamesM
You may appreciate this data which is represent... Jun 9 2026, 04:00 PM
wonkipop
You may appreciate this data which is represen... Jun 9 2026, 04:23 PM
Superhawk996
wondering if there are things I can implement to ... Jun 9 2026, 06:32 PM
JamesM
wondering if there are things I can implement to... Jun 10 2026, 08:12 AM
Superhawk996 its an interesting problem to think about.
Inde... Jun 10 2026, 12:53 PM
JamesM
Ind... Jun 11 2026, 02:27 PM
Superhawk996
[quote name='Superhawk996' post='3260817' date='J... Jun 11 2026, 05:21 PM
Nogoodwithusernames What does your tune look like? I followed John Con... Jun 11 2026, 11:03 AM
JamesM
What does your tune look like? I followed John Co... Jun 11 2026, 07:19 PM
Jack Standz You must realize that the cylinders in a type iv m... Jun 8 2026, 03:27 PM
porschetub I did a slight mod to the factory mounting bracket... Jun 8 2026, 09:41 PM
emerygt350 Here are some data points on flap activity. Drove... Jun 9 2026, 10:20 AM
Superhawk996
:t... Jun 9 2026, 11:40 AM
JamesM
:... Jun 9 2026, 04:19 PM
Superhawk996
Would be awesome to setup probes to get ambient... Jun 9 2026, 06:29 PM
Superhawk996 doh. Doublepost Jun 9 2026, 06:29 PM
emerygt350 After I loaded my clubs into the car I headed to t... Jun 9 2026, 10:21 AM
JamesM
Notice the cht and the oil temps
This is a 200... Jun 9 2026, 03:48 PM
emerygt350
This is a 20... Jun 9 2026, 03:59 PM
emerygt350 I do have a cheap go pro.... Talk about a movie o... Jun 9 2026, 11:49 AM
emerygt350 Arduinos are cheap and the selection of sensors ar... Jun 9 2026, 07:49 PM
Superhawk996
Arduinos are cheap and the selection of sensors a... Jun 9 2026, 07:55 PM
930cabman Wondering if the boys (girls) in the fatherland we... Jun 11 2026, 11:35 AM
Root_Werks I'm one of those weird people that installed a... Jun 11 2026, 11:56 AM
930cabman
I'm one of those weird people that installed ... Jun 11 2026, 01:19 PM
73-914
I'm one of those weird people that installed ... Jun 12 2026, 11:00 AM
Root_Werks
I'm one of those weird people that installed... Jun 12 2026, 11:10 AM
dr914@autoatlanta.com never Jun 11 2026, 02:47 PM
Jack Standz As has been said before, this is awesome! ... Jun 11 2026, 02:57 PM
emerygt350
As has been said before, this is awesome! ... Jun 11 2026, 05:43 PM
Superhawk996
[quote name='Jack Standz' post='3260973' date='Ju... Jun 12 2026, 06:55 AM
brant Full load redline is the most important for mixtur... Jun 11 2026, 07:34 PM
JamesM Ok, you said I was still on topic so... here goes,... Jun 11 2026, 10:03 PM
emerygt350 Great, now I need a new efi.... Jun 12 2026, 04:19 AM
930cabman Go James Go
I'm sure it's all good stuff,... Jun 12 2026, 04:50 AM
rudedude @jamesm
Would you share your microsquirt tables?.... Jun 12 2026, 07:20 AM
JamesM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 16 2026, 09:02 PM
JamesM
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jun 16 2026, 09:19 PM
VaccaRabite Late to the conversation.
I have always run with ... Jun 13 2026, 08:40 PM
JamesM
I have always run with... Jun 13 2026, 09:06 PM
emerygt350 I think I may have read somewhere that the lowest ... Jun 14 2026, 05:28 AM
JamesM
I think I may have read somewhere that the lowest... Jun 15 2026, 05:50 PM
wonkipop
I think I may have read somewhere that the lowes... Jun 15 2026, 06:15 PM
bdstone914 I have never liked the failure prone thermostat an... Jun 14 2026, 01:13 PM
Jack Standz What do you think about a switch triggering electr... Jun 14 2026, 01:39 PM
iankarr Another thing to consider if you're in the ... Jun 14 2026, 07:45 PM
Dave_Darling Deleting the T-stat [b]and flaps ...
Deleting t... Jun 17 2026, 11:22 PM
930cabman This is all great info, can anyone provide a sourc... Jun 15 2026, 01:05 PM
friethmiller
This is all great info, can anyone provide a sour... Jun 15 2026, 01:11 PM
930cabman Have one on the way, thanks for the link
:beer1: Jun 15 2026, 04:07 PM
Superhawk996
Do folks have any insight as to why the air-coole... Jun 16 2026, 04:42 AM
BillC
[quote name='frank_c' post='3261576' date='Jun 16... Jun 16 2026, 12:02 PM
wonkipop
[quote name='frank_c' post='3261576' date='Jun 16... Jun 16 2026, 04:19 PM
wonkipop
Do folks have any insight as to why the air-coole... Jun 16 2026, 04:17 PM
Superhawk996
Do folks have any insight as to why the air-cool... Jun 17 2026, 09:56 AM
wonkipop
[quote name='Krieger' post='3261750' date='Jun 17... Jun 17 2026, 12:33 PM
emerygt350 At the Porsche parade it was 55 degrees yesterday.... Jun 16 2026, 04:41 AM
Jack Standz A tatra?
How about a flat six aircooled "Mer... Jun 16 2026, 04:38 PM
Superhawk996
A tatra?
Hle2_Dy-UW8?is=TeHJIYPptzkPAR3_ Jun 16 2026, 06:09 PM
Jack Standz That is unusual and am pretty sure never heard of ... Jun 16 2026, 08:44 PM
930cabman
That is unusual and am pretty sure never heard of... Jun 17 2026, 04:50 AM
73-914
That is unusual and am pretty sure never heard o... Jun 17 2026, 09:44 AM
Jack Standz Yes, was thinking about the old cast iron and bira... Jun 17 2026, 10:30 AM
Superhawk996 Julius Mackerle designed that v8 engine and later ... Jun 17 2026, 11:18 AM
930cabman
Julius Mackerle designed that v8 engine and later... Jun 17 2026, 11:24 AM
Superhawk996
Is anybody making an air cooled vehicle these da... Jun 17 2026, 11:33 AM
Jack Standz
[quote name='930cabman' post='3261770' date='Jun ... Jun 17 2026, 01:13 PM
wonkipop just getting back to tatras for a moment.
and to a... Jun 18 2026, 04:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th June 2026 - 03:23 AM |
