> Convert back to D Jet Fuel Injection-, Distributor Static Timing.
young55961
post Jun 19 2026, 01:32 PM
I set the engine to TDC on cylinder #1. The timing mark is lined up with the case split. Both the intake and exhaust rocker arms have a little movement when I turn the fan pulley slightly left and right.
The distributor rotor is pointing to about the 8 o'clock position.
Does this look correct?
Also, how do I set the static ignition timing on this engine?
Artfrombama
post Jun 19 2026, 02:38 PM
Artfrombama
QUOTE(young55961 @ Jun 19 2026, 02:32 PM) *
Both cyl. #1 valves should be closed to be on TDC compression, otherwise the engine is on TDC exhaust stroke
I use a continuity tester to set static timing. Align your timing marks and slowly turn the distributor until the points break (no continuity)
9 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th June 2026 - 06:06 PM
