> Convert back to D Jet Fuel Injection-, Distributor Static Timing.
young55961
post Jun 19 2026, 01:32 PM
I set the engine to TDC on cylinder #1. The timing mark is lined up with the case split. Both the intake and exhaust rocker arms have a little movement when I turn the fan pulley slightly left and right.
The distributor rotor is pointing to about the 8 o'clock position.
Does this look correct?
Also, how do I set the static ignition timing on this engine?
Jack Standz
post Jun 19 2026, 03:30 PM
If the #1 intake and #1exhaust rocker arms are moving at/around "TDC", you are not at TDC for the #1 cylinder's compression stroke.
You could be at TDC for the #1 cylinder but you may be on the exhaust stroke, but maybe not. Reconfirm everything. Things like the fan marking for TDC (some Type IV motors don't have a mark on the fan for TDC), where the distributor is installed, etc.
young55961
post Jun 19 2026, 04:52 PM
QUOTE(Jack Standz @ Jun 19 2026, 04:30 PM) *
I checked both the fan and the flywheel, and all the timing marks line up.
I rotated the engine one full revolution, and now the rotor is pointing to the 2 o'clock position. The problem is that the air temperature sensor is blocking distributor vac. I have to remove the sensor; otherwise, I can't set the timing.
10 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 19th June 2026 - 06:07 PM
