> 2 liter engine swap question. Oil pressure sensor?
roundtwo
post Jun 23 2026, 04:48 PM
Have a 1971 that I purchased a few years back from the original owner. He upgraded it to a 2 L some time back.
Fortunately, I have a 2 L that I bought from a customer at Eason Auto Works who was upgrading to a six in his 914. It had all the documentation from the rebuild and only about 35K on it.
Fast-forward to now and I’m transplanting that engine into the 1971.
See pictures.
Pic 1. Replacement engine with sensor.
Pic 2. Original engine with oil pressure
Pic 3. Original engine sending unit (?)
Original engine in picture number one and number two. Oil pressure sensor next to the distributor.
The replacement engine I have only has an engine temperature sensor? in the same spot.
Car has a oil pressure gauge
Do I need remove the engine tin to swap out the base of the oil pressure fitting?
I’m not sure what I’ll find under there.
I would like a working gauge, but I’ve read on some of the forums that having an oil pressure sensor leak rapidly can be catastrophic if it fails
Appreciate some advice about this. .
Montreal914
post Jun 23 2026, 08:58 PM
Your picture #3 shows the oil pressure sender. This model has two connection points, one is for the pressure gauge and the other is for the pressure light if I recall. That being said, I am not sure if the trigger for the pressure light is set at the same pressure as the stock one you show in picture 2.
Important, the ouside shell of the pressure sender (picture 3) needs to be connected to ground. Notice the metal clamp around it, make sure it is fastened to make ground.
That's all I have, other will chime in. Good luck! (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 23rd June 2026 - 11:36 PM
