| EJP914 |
Jun 24 2026, 09:10 AM
Member ![]() ![]() Group: Members Posts: 295 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
hello!
Looking for some ideas on why the spark plug electrodes are wet with gas after running the car for only about 20-30 seconds. Something is causing way too much fuel into the engine. Car starts at the turn of the key, but stumbles and runs rough. Exhaust smells like gasoline. I have checked, replaced, or installed known good parts. New plugs, points, condenser. Cleaned trigger contacts. Distributer other wise works as it should. Swapped in known good relay board and relays Swapped in known good ECU. Installed new fuel injectors, Standard Mfg type. Fuel line pressure at 25 lbs. Swapped in “adjusted” MPS. (Maybe still too rich?) Timing is good but not spot on. I have not yet checked CHT sensor or cold start valve (may be stuck open?). Not sure what else to check? I have never seen this much gas get pumped into an engine. I would very much appreciate any advice and/or guidance. Thanks. EJP914 |
| brant |
Jun 24 2026, 09:43 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,218 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
CHT and mps failure both cause excessive rich conditions
EJP914 Way too much gas Jun 24 2026, 09:10 AM
FlacaProductions I'd check the cold start valve. Jun 24 2026, 09:13 AM
JamesM
Swapped in “adjusted” MPS. (Maybe still too ... Jun 24 2026, 09:43 AM
emerygt350 Check you cht just in case. Easy peasy. Then che... Jun 24 2026, 10:08 AM
burton73 I don't know why your car is pumping too much ... Jun 24 2026, 10:30 AM
emerygt350
I don't know why your car is pumping too much... Jun 24 2026, 02:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 03:13 PM |
