| StarBear |
Jun 24 2026, 10:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,321 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
74 1.8L
Had clutch replaced and shop didn’t reconnect the ground strap when putting the trans back up. Hence the sluggish starting issue. Couldn’t find where to connect it to the trans, so connected it to the engine mount bolt (ground confirmed; see pic). New OEM strap is same length as old. I’ve replaced it before but don’t think I used the engine mount. Where should it go on the trans? |
| Luke M |
Jun 24 2026, 10:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,549 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
The ground strap attaches at the transmission tail housing. Remove an upper nut and install the strap.
Heck if you look you may find that the shop either left the nut loose or removed it from where the strap belongs. |
StarBear Trans ground strap Jun 24 2026, 10:41 AM
GregAmy Concourse-wise I have no clue. But functionally, t... Jun 24 2026, 10:50 AM
StarBear
The ground strap attaches at the transmission tai... Jun 24 2026, 12:07 PM
StarBear
The ground strap attaches at the transmission tai... Jun 24 2026, 12:08 PM
StarBear Thanks! Will look again. Jun 24 2026, 12:07 PM
Jack Standz You were very fortunate that you didn't have a... Jun 24 2026, 12:15 PM
StarBear
You were very fortunate that you didn't have ... Jun 24 2026, 01:19 PM
JeffBowlsby That ground strap attaches to a pressed-in threade... Jun 24 2026, 01:10 PM
StarBear
That ground strap attaches to a pressed-in thread... Jun 24 2026, 01:17 PM
GregAmy Anyone have a pic of the location where it connect... Jun 24 2026, 01:29 PM
StarBear
Anyone have a pic of the location where it connec... Jun 24 2026, 01:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 03:13 PM |
