| StarBear |
Jun 24 2026, 10:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,321 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
74 1.8L
Had clutch replaced and shop didn’t reconnect the ground strap when putting the trans back up. Hence the sluggish starting issue. Couldn’t find where to connect it to the trans, so connected it to the engine mount bolt (ground confirmed; see pic). New OEM strap is same length as old. I’ve replaced it before but don’t think I used the engine mount. Where should it go on the trans? |
| Jack Standz |
Jun 24 2026, 12:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 858 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
You were very fortunate that you didn't have a fire. Good to hear that it didn't happen.
When the transmission ground strap is left disconnected, your clutch cable is the likely path for electricity. Just ask George Hussey about his experience when he left off the ground strap (he just had to install a new clutch cable and reconnect the ground strap). |
| StarBear |
Jun 24 2026, 01:19 PM
You were very fortunate that you didn't have a fire. Good to hear that it didn't happen. When the transmission ground strap is left disconnected, your clutch cable is the likely path for electricity. Just ask George Hussey about his experience when he left off the ground strap (he just had to install a new clutch cable and reconnect the ground strap). Whew! Since it did start albeit sluggish my guess the strap was still touching the trans case, just not real solidly. (IMG:style_emoticons/default/beer3.gif) |
StarBear Trans ground strap Jun 24 2026, 10:41 AM
GregAmy Concourse-wise I have no clue. But functionally, t... Jun 24 2026, 10:50 AM
Luke M The ground strap attaches at the transmission tail... Jun 24 2026, 10:50 AM
StarBear
The ground strap attaches at the transmission tai... Jun 24 2026, 12:07 PM
StarBear
The ground strap attaches at the transmission tai... Jun 24 2026, 12:08 PM
StarBear Thanks! Will look again. Jun 24 2026, 12:07 PM
JeffBowlsby That ground strap attaches to a pressed-in threade... Jun 24 2026, 01:10 PM
StarBear
That ground strap attaches to a pressed-in thread... Jun 24 2026, 01:17 PM
GregAmy Anyone have a pic of the location where it connect... Jun 24 2026, 01:29 PM
StarBear
Anyone have a pic of the location where it connec... Jun 24 2026, 01:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 03:13 PM |
