| Boothy |
Jun 25 2026, 09:36 AM
Member ![]() ![]() Group: Members Posts: 110 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States |
Greetings all!
I haven't bothered you guys in over a year I think -you're welcome. Last fall the new engine started smoking and the tail pipes were black. Sluggish. I think I rejetted at some point but can't recall. Naturally I assumed I burned something up or broke a ring etc. so I put it under a cover for the winter. Bought a compression tester but I was so fed up I just said screw it till spring. Refreshed and ready to look at it again, I looked online thinking I'll start with jetting. I have Weber 40s on a 1.7 punched out to 2.0. I was at 185 mains but another AI search (I know I'll hear about that) said go to 1.15 mains and 2.00 air correction. Seemed to cleanup last night and I'll run it some more today. But now it pops a little on deceleration. Sounds better -cleaner. Looking the popping might be a too lean condition, air leak near the exhaust flange, etc. BUT, I had a lot of trouble with the timing mark on the fan so I'm not 100% sure I have it where it's supposed to be. Despite multiple efforts (looking at lots of pictures of the fan marks) I'm just not sure. I know it sounds hack but I'm wondering if I can advance the 123 distributor a little at a time manually. I'll do a compression test tomorrow to be sure but thought I'd throw it out to the gods. Thanks in advance! |
| brant |
Jun 25 2026, 10:51 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,220 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
You have to have the timing correct first before you can tune the carbs
Boothy Timing Jun 25 2026, 09:36 AM
emerygt350 Did you test the compression?
I time mine off the... Jun 25 2026, 10:03 AM
Superhawk996
You have to have the timing correct first before ... Jun 25 2026, 12:01 PM
Boothy Okay. Thank you. Forgot about the flywheel. What a... Jun 25 2026, 12:17 PM
BillC
Okay. Thank you. Forgot about the flywheel. What ... Jun 25 2026, 12:54 PM
emerygt350 Since you have a 123 you need to set it up as the ... Jun 25 2026, 01:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2026 - 01:16 PM |
