| Jezibel |
Jun 28 2026, 06:23 PM
Das Echte POORSCHE Fahrer ![]() ![]() Group: Members Posts: 69 Joined: 21-January 24 From: Northern California Member No.: 27,868 Region Association: Northern California |
Main lighting switch raises lamps, lights up, but pushing switch back in fails to lower the lights.
AI says 1) Check fuses for failed or faulty fuse; 2) check headlight relay on fuse-box backside; 3) check grounds; 4) check headlights switch for possible corrosion on contacts. System was working fine last week. It just decided today to not lower the lamps. I have a replacement main lighting switch on order, also several Bosch 5-pin relays, and all the fuses check out OK (no corrosion on fuse block contacts. I lowered the headlights manually, using the motor-end knobs, per the protocol, but it irritates me to not be able to immediately fix this apparently quite common problem on my '74 1.8 liter. Any helpful suggestions, other than the cited "4-most likely causes' AI pointed out, above? Thanks in advance. |
emerygt350
Main lighting switch raises lamps, lights up, but... Jun 28 2026, 08:29 PM
Jezibel No, I did not. Where are they located in the frunk... Jul 5 2026, 04:41 PM
Jezibel
[size=5]No, I did not. Where are they located in ... Jul 5 2026, 04:58 PM
Jezibel
[quote name='Jezibel' post='3264161' date='Jul 5 ... Jul 5 2026, 05:04 PM
L-Jet914 The relays for each headlight motor is mounted und... Jul 5 2026, 05:13 PM
cgnj @[url=http://www.914world.com/bbs2/index.php?showu... Jul 5 2026, 05:17 PM
Cairo94507 Buy a couple of new headlight relays and swap them... Jul 6 2026, 03:52 PM
fixer34 This from the pelican article:
"The first... Jul 6 2026, 05:36 PM
Jezibel
"The firs... Aug 13 2026, 06:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th August 2026 - 01:45 AM |
