> What and How is this fixing intermittent no start, .. Mayo Performance solution
Literati914
post Jul 3 2026, 02:30 PM
My friend took his car to Ed Mayo of Mayo Performance to fix a no start after driving issue. Ed has been working on these cars since new and he knew exactly what the trouble was. He installed the item in the following picture and all is well now. He said they even used to have to do this to NEW 914s back in the day!
He explained it to my friend who only caught bits of the explanation. Something along the lines of the wire to the starter getting hot and needing a 1/2 volt extra from this add on, to overcome the issue.
I assume it’s the typical heat related issue. BTW I think a lot of people assume vapor lock is the only heat related problem (fuel pump is in the front on this car). Can someone give a thorough explanation for what this is addressing and how? I’d love to see a wiring scheme of this fix also.
JamesM
post Jul 3 2026, 04:11 PM
I view these as more of a band-aid. Yes they are a solution but if you properly address the underlying problem its unnecessary.
I have had my hands on a LOT of 914s, never had to install a hot start relay, and in fact have removed quite a few of them.
Underlying issue is usually voltage drop at the ignition switch contact, crappy starter solenoid, or both.
I find the solenoids used on the modern gear reduction starters to be a lot less temperamental than the ones used on the factory/rebuilt starters.
Superhawk996
post Jul 3 2026, 04:46 PM
QUOTE(JamesM @ Jul 3 2026, 06:11 PM) *
I have seen excessive voltage drop on the yellow stater wire multiple times as a root cause. The source of the voltage drop has always been at one end termination or the other. I have yet to find one where I had to replace the actual wire. I’m sure someday I’ll find one where the actual wire needs to be replaced but haven’t encountered that yet.
The core problem is the inability of most shops and DIY’ers to be able to properly diagnose and repair wiring issues.
Other issues this quick fix often hides . . . For a while.
Bad ground from trans to chassis (often sourcing ground thru clutch cable - leading to eventual breakage of the clutch cable).
Bad negative ground cable from battery to chassis
Extreme corrosion between the starter itself and the transmission (ie another bad ground)
Bad positive battery cable to the starter lug.
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: dtmehall
- Lo-Fi Version Time is now: 3rd July 2026 - 05:59 PM
