| Jezibel |
Jul 9 2026, 03:08 PM
Das Echte POORSCHE Fahrer ![]() ![]() Group: Members Posts: 69 Joined: 21-January 24 From: Northern California Member No.: 27,868 Region Association: Northern California |
Hi folks. I need to find a 914-4 Combi headlight 4-pin relay, Porsche 111-941-583A, which everyone tells me simply do not exist any more (except as perhaps salvaged 'used' parts). Auto Atlanta, SMC, 914 Rubber, et al, all offer the 5-pin relay (111-941-583) that fits '75/'76 914s as a replacement, which of course the earlier 4-pin cars they are not compatible with.
This is a real stumper and I know that many of you may have likely encountered this frustration in the past. What I need to know is 1) Does anyone still sell the 4-pin relays or is everyone selling the incompatible 5-pin relays? 2) Are they available anywhere other than possibly via salvaged units from junk yards? You'd think that there would still be some of these floating around in Germany or England, but so far I've had no luck pursuing that option. I can't believe that some bright person hasn't figured out that this is a BIG problem that cries for redress. I know that the 111-941-583A relay rarely fails, but if they do, a replacement is the only option. I am also aware of the fact that a similar appearing relay made by VW starting with 381 that is a 4-pin relay appears as if it might be the same 4-pin headlight 'Combi' relay, but have no confirmation of that. I know there was a thread on this some time ago but don't know how to all it up. At any rate, even there they had no ready solutions to this perplexing problem. Any helpfull insights would be most appreciated! I also hear that some Chinese-made 111-941-583 relays have been 'bridged' so as to work, but I'm not well informed about that and it sounds rather precarious to me to use one (if they are even offered anywhere). |
| ejm |
Jul 10 2026, 04:52 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,718 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
@Jezibel The relay that you are asking about is the hi/low beam relay.
It has nothing to do with the headlights not retracting. Assuming the headlights go up when you turn them on but not down when off the problem is most likely the headlight switch. |
Jezibel 914-4 headlight 'Combi Relay' 111-941-583A Jul 9 2026, 03:08 PM
porschetub
Hi folks. I need to find a 914-4 Combi headlight ... Jul 9 2026, 08:01 PM
914Sixer EBAY Jul 10 2026, 06:08 AM
sixnotfour If you cant waite or want to update,,,run a jumper... Jul 10 2026, 06:50 AM
fixer34 Is this what you are looking for? Also called a l... Jul 10 2026, 03:07 PM
Jezibel
Is this what you are looking for? Also called a ... Jul 12 2026, 01:20 PM
Jezibel Yep. The 'Latching-type' headlight low/hig... Jul 16 2026, 12:15 PM
Jezibel
Yep. The 'Latching-type' headlight low/hi... Jul 16 2026, 01:53 PM
Jezibel As long as we're discussing the 'Combi-rel... Jul 16 2026, 02:04 PM
Jezibel
As long as we're discussing the 'Combi-re... Jul 17 2026, 12:49 PM
fixer34 If yours has the metal 'can', carefully be... Jul 10 2026, 03:13 PM
Jezibel
If yours has the metal 'can', carefully b... Jul 12 2026, 01:08 PM
Jezibel
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 12 2026, 01:09 PM
porschetub :agree: ,check the wiring up to the switch also ,n... Jul 10 2026, 10:27 PM
Jezibel
:agree: ,check the wiring up to the switch also ,... Jul 12 2026, 01:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th August 2026 - 11:49 PM |
