| 914werke |
Jul 11 2026, 05:31 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,692 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
So Ive done a lot of brakes, but this is the first time Ive experienced this one.
Had a OE MC fail, got my hands on one of the NEW 17mm units, Replaced F. calipers with rebuilt, + all the soft lines, the MC & the (Blue) res. line sections. All went as expected. No drama just the typical PITA installing the MC. Went about bleeding & got the pedal to near the point I thought I was done when testing a full pressure hold ...the pedal travel "breaks" & continues to the floor. (IMG:style_emoticons/default/headbang.gif) I think Ive got a leak but inspection shows its all still dry... (IMG:style_emoticons/default/blink.gif) Can a MC fail internally? Anyone witha BTDT? |
| 914werke |
Jul 11 2026, 06:07 PM
pressure/fails/drops to floorboard a few times. See if master fluid level stays the same. If so, they only thing can it can be doing is internal bypass in the master. Bad master! Help me out the plunger circuit is a Aluminum piece with a pair of wiper seals, behind it is a pretty beefy spring? What fails, the spring? |
| Superhawk996 |
Jul 11 2026, 06:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,941 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
pressure/fails/drops to floorboard a few times. See if master fluid level stays the same. If so, they only thing can it can be doing is internal bypass in the master. Bad master! Help me out the plunger circuit is a Aluminum piece with a pair of wiper seals, behind it is a pretty beefy spring? What fails, the spring? It’s usually the seals that fail and allow an internal bypass |
914werke OK I need some brake help.. Jul 11 2026, 05:31 PM
Ninja The aftermarket (usually Chinese) ones do all of t... Jul 11 2026, 05:51 PM
914Sixer Rich,
Did you bleed the MC before installing? I c... Jul 11 2026, 06:05 PM
914werke
Rich,
Did you bleed the MC before installing? I ... Jul 11 2026, 06:08 PM
914werke RE: OK I need some brake help.. Jul 11 2026, 06:40 PM
SO.O.C914er
Breathe Rich breathe help is on the way! I ... Jul 11 2026, 07:30 PM
Superhawk996
The problem is that I was a brake engineer for... Jul 11 2026, 07:56 PM
SO.O.C914er Oh and I’m saving this most interesting man.
Th... Jul 11 2026, 07:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th July 2026 - 08:23 PM |
