| frank_c |
Jul 15 2026, 07:46 PM
Member ![]() ![]() Group: Members Posts: 97 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
As the title states, I'm trying to determine if the VDO CHT Gauge uses K or J-Type Thermocouple (TC).
Backstory: My '76 2.0 has a VDO CHT gauge installed by a PO (photo 1). I know there are better options out there, and I plan to replace it with something better the next time I drop the engine, but for now my main goal is to to get the VDO back to a functional state. The PO installed the thermocouple at the stock temp sensor location @Cyl #3 on the 2.0 head. In addition, the "Cold Junction" for the TC wiring was in the engine bay near the distributor. So, in an effort to provide a more accurate temperature reading, when I had the engine out last winter, I: 1. Replaced the old TC with a K-Type TC located under the #3 spark plug (photo 2) 2. Used a special K-Type connector in the engine bay and extended the K-Type TC wire all the way to the gauge (cold junction at gauge). The gauge needle did not move upon my initial test. To ensure the gauge was still good, I hooked it up directly to the old TC that I removed and heated the TC with a heat gun. The needle moved after I swapped +/-. I then re-connected the new TC wire I ran, this time swapping the +/- terminals, started the engine and confirmed that after a few minutes the needle moved (yay). Apparently, per the below Samba thread, some VDO CHT gauges have their +/- terminals swapped, so that solves that mystery: https://www.thesamba.com/vw/forum/archive/i...t-173868--.html But I noticed something else during this process which is why I'm asking about the TC type. I purchased K-type TC and wiring because what I read up until that point indicated the the VDO gauge used a K-Type TC. The K-Type TC wiring is color coded Yellow(+) and Red(-) [ see chart below]. However the wiring on the old TC I removed is Red(ish)/White. And according to the TC color chart, Red/White is a J-Type TC. To confirm, I checked and found that the White(+) lead of the TC I removed is indeed magnetic. I then found this thread on Shop Talk Forums stating that the VDO CHT actually uses a J-Type TC, not a K-Type as most commonly thought: https://shoptalkforums.com/viewtopic.php?t=144947 If it turns out that the VDO gauge does indeed use a J-Type TC, then since I already have the K-Type TC, connector, and wiring installed, the easiest path forward for me is to simply purchase a K-Type gauge (which may pose a new challenge). If it uses a K-Type, then I should be good for now. Sorry for the long post. Looking forward to hear what folks have to say who have been down this path already. ![]() |
| Superhawk996 |
Jul 15 2026, 09:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,950 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Ah if only life were so black and white.
Once upon a time (80s) I had an VDO with a J-type red and white thermocouple I’ll leave the whole cold junction discussion for another time. If OP truly wants to keep K-type thermocouple and wiring - then go for the Dakota. The cold junction compensation is a bonus. Note: negative lead of K-type (red) is Alumel and that is also highly magnetic. The magnet test is useful for determining the negative lead of either a J-type or K-type thermocouple but isn’t useful for determining one type vs the other. Note 2: color codes for thermocouples are not standardized internationally. |
| frank_c |
Jul 15 2026, 09:43 PM
Once upon a time (80s) I had an VDO with a J-type red and white thermocouple Hmm, curiouser and curiouser. The date code on my gauge is 7/86. Now I'm not sure what my gauge is (J or K). Why would the PO have used a J-Type TC (assuming the red/white is correct) if it was a K-Type gauge? In addition, the gauge did show temperatures in appropriate CHT range with the old TC. ![]() If OP truly wants to keep K-type sensor and wiring - then go for the Dakota. The cold junction compensation is a bonus. Given the number of unknowns here, I think you guys have convinced me to just move to a new gauge. I was trying to keep with analog gauges, but the DD looks like the way to go. Does anyone know if the Micro 1000 uses a K-Type TC? https://www.aircraftspruce.com/catalog/inpa.../CHT_gauges.php Note: negative lead of K-type (red) is Alumel and that is also highly magnetic. The magnet test is useful for determining the negative lead of either a J-type or K-type thermocouple but isn’t useful for determining one type vs the other. As usual, Superhawk is correct. I was going by the chart I posted that listed only the J-Type + lead as being magnetic, but I just went an checked and the K-Type is also magnetic. Thanks. So the old red/white TC I removed may or may not be J-Type. One more unknown. |
frank_c Does the VDO CHT Gauge use a K or J-Type Thermocouple? Jul 15 2026, 07:46 PM
VaccaRabite K type.
And replace it NOW with something that is... Jul 15 2026, 08:32 PM
FlacaProductions https://www.dakotadigital.com/index.cfm/pag...prod... Jul 15 2026, 08:56 PM
Superhawk996
Once upon a time (80s) I had an VDO with a J-typ... Jul 15 2026, 09:57 PM
Montreal914 More countries chart.
For the gauge there is a... Jul 15 2026, 11:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th July 2026 - 02:01 AM |
