> Static timing 73 1.7, Doing something wrong
EJP914
post Jul 27 2026, 06:05 PM
I am attempting to static time my car after a local shop had it for 4 months and did not fix it.
I am following these abbreviated instructions…
Remove cap, rotor points to #1 on the cap.
Using a 12v test light with clip end to ground and pointy end to the neg side of the coil.
Loosen dizzy clamp bolt. Turn on ignition.
Rotate dizzy clockwise until test light goes out.
Turn back counterclockwise (the direction the rotor spins) until light goes back on.
Tighten clamp, etc.
Sounds ample enough.
I can turn the distributor quite a ways clockwise and the test light never goes out.
Why would that be?
Also, doesn’t the rotor turn clockwise?
Would appreciate any directions, help and criticism. Even simple electronics baffle me.
Thanks
EJP914
EJP914   Static timing 73 1.7   Jul 27 2026, 06:05 PM
Jack Standz   Guessing it's a point type distributor? Just ...   Jul 27 2026, 06:16 PM
dtmehall   check out this link on timing the 914 https://www...   Jul 27 2026, 06:24 PM
emerygt350   Don't overthink it. As stated above, verify t...   Jul 27 2026, 07:40 PM
dtmehall   :agree:   Jul 27 2026, 08:10 PM
- Lo-Fi Version Time is now: 28th July 2026 - 12:33 AM
