| scott_in_nh |
Jul 27 2026, 07:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 816 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I'm trying to get everything together that I will need to finally drop the motor so I won't have any excuses left to keep kicking the can....
I need a new floor jack anyway, and I want to buy the Tangerine lifting plate. Any advantages/disadvantages of using the post model vs the Allen screw model? What size and type of jack? limited use so Harbor Freight models or similar are fine. What is the best height for dropping the motor? The car will be level unless there is a reason for it not to be. Thanks |
| Superhawk996 |
Jul 27 2026, 08:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,048 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Tallest Daytona jack you can get and the tangerine lift plate.
Don’t cheap out on the Jack. A good Jack makes a huge difference. I’ve done drops on everything from an el cheap K-mart two ton which was tippy and too short to a good Daytona (the snap-on knockoff). The stability of the jack makes a world of difference. ![]() And make sure you have jackstands too. Never get under a car without jackstands. |
| scott_in_nh |
Jul 28 2026, 10:48 AM
Tallest Daytona jack you can get and the tangerine lift plate. Don’t cheap out on the Jack. A good Jack makes a huge difference. I’ve done drops on everything from an el cheap K-mart two ton which was tippy and too short to a good Daytona (the snap-on knockoff). The stability of the jack makes a world of difference. And make sure you have jackstands too. Never get under a car without jackstands. Thanks, is that the tube type or bolt type? |
scott_in_nh what floor jack and engine lift plate should I get? Jul 27 2026, 07:21 AM
930cabman
Tallest Daytona jack you can get and the tangerin... Jul 27 2026, 09:16 AM
Superhawk996
Tallest Daytona jack you can get and the tangeri... Jul 28 2026, 11:49 AM
TRP I have two of the Daytona jacks and the bolt throu... Jul 27 2026, 09:32 AM
emerygt350 I always put the tires under the carr as well as t... Jul 27 2026, 10:23 AM
johnhora Worth every $$ for doing this job....mak... Jul 27 2026, 10:31 AM
L-Jet914 I haven't pulled my own engine yet, but I use ... Jul 27 2026, 03:39 PM
mepstein I have a used tangerine plate that I need to sell.... Jul 27 2026, 04:04 PM
scott_in_nh
I have a used tangerine plate that I need to sell... Jul 28 2026, 10:48 AM
Nana's_914 Don't forget Wheel Chocks.
https://www.harbo... Jul 27 2026, 04:05 PM
NARP74 AC Hydraulic has some great high lift floor jacks ... Jul 27 2026, 04:35 PM
sixaddict I have had AC Hydraulics jack for longer than I ca... Jul 27 2026, 05:27 PM
930cabman IIRC there was some machine work involved to adapt... Jul 28 2026, 10:56 AM
Superhawk996
IIRC there was some machine work involved to adap... Jul 28 2026, 11:26 AM
930cabman I purchased my HF Daytona jack a year or so ago an... Jul 28 2026, 12:18 PM
ChrisFoley Take your time making up your mind, Scott. :)
I so... Jul 29 2026, 11:24 AM
scott_in_nh
I s... Jul 29 2026, 01:29 PM
jim_hoyland :popcorn: Details please..,, Jul 29 2026, 07:20 PM
scott_in_nh
the 914 or the bo... Jul 30 2026, 06:20 AM
sithot A fellow I know did a 996GT3 engine conversion and... Sep 15 2026, 12:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 03:05 PM |
