| roundtwo |
Jun 13 2021, 06:48 PM
Member ![]() ![]() Group: Members Posts: 372 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California
Trying to get prepped for all my welding needs. Id like to Pre-fit the rear sway bar so I can determine exactly we’re to mount the bushing mount backing plates. I want to be sure they’re perpendicular to the sway bar in just the right spot
1. See first pick. Do I install the bushings in the drop links first and then install the ball ends? Or, do I install the ball cups on the balls and then have them pressed into the drop links? Any tips on how to get these hard bushings into the drop links? 2. Do I simply replace the new shock base metal rod labeled #1 with #2. See second pic I’ve read the rear sway bar mounts instructions on the Pelican Parts web site. Very helpful- He just doesn’t cover the actual sway bar assembly. Bar is 16mm. Installing on a 1970. Many thanks. |
| TonyA |
Jul 28 2026, 03:58 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 725 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
I used a pair of cabinet clamps from harbor freight and some glycerin and heated in hot water. popped right on. The shock bolt should be real bright and shiny.
roundtwo Rear Sway bar install Jun 13 2021, 06:48 PM
roundtwo Adding sway bar on this build
Jun 13 2021, 06:50 PM
ClayPerrine The big bolt with the ball end replaces the lower ... Jun 13 2021, 07:07 PM
bkrantz I put the bushings into the drop links first (used... Jun 13 2021, 07:38 PM
barefoot
I put the bushings into the drop links first (use... Jun 14 2021, 11:12 AM
ClayPerrine
I put the bushings into the drop links first (use... Jun 14 2021, 12:21 PM
NARP74 I just went through this, mine had the mounting br... Jun 14 2021, 12:41 PM
roundtwo Appreciate all the secrets!
Able to get in th... Jun 14 2021, 07:39 PM
76-914 Do like Clay said. A giant pair of channel locks a... Jun 14 2021, 08:55 PM
roundtwo
Do like Clay said. A giant pair of channel locks ... Jun 14 2021, 10:43 PM
LefthandRev I used a heat gun, a dull flat head screwdriver, a... Dec 22 2021, 03:58 PM
TRP
I used a heat gun, a dull flat head screwdriver, ... Oct 18 2025, 11:19 PM
wonkipop
I used a heat gun, a dull flat head screwdriver,... Oct 19 2025, 12:08 AM
TRP Today I wrapped up the rear sway bar today. This w... Oct 19 2025, 09:12 PM
914werke . I used glycerin. I didn't need to heat them... Dec 22 2021, 04:53 PM
porschetub
I used a pair of cabinet clamps from harbor freig... Jul 28 2026, 06:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th October 2026 - 12:56 AM |
