> troubleshooting stalling when idling hot, idle/mixture adjustment?
timofly
post Jul 29 2026, 01:03 PM
'74 2.0 with .010 oversize cylinders, original Jetronic fuel injection intact and works great 95% of the time. However, engine idles very slowly (almost off the bottom of the tach scale) and will eventually stall unless throttle is "goosed". Condition only occurs in high ambient temps after 15-20 minutes driving. Then hard to start without a bit of throttle, but starts fine with that little bit of throttle, so I don't think it's fuel vaporization. (Fuel pump has been moved forward and fuel lines are all SS.)
Runs normally otherwise. Cylinder head temp sensor? Idle adjustment? What? Any ideas would be appreciated.
Tim
914werke
post Jul 29 2026, 01:16 PM
On top of the AFM is a recessed screw to adjust idle mix.
it will have IDK 12 or 14 discernible detent's. Verify where its currently set and
increase adjustment as necessary 1 at a time
timofly
post Jul 29 2026, 02:13 PM
QUOTE(914werke @ Jul 29 2026, 03:16 PM) *
I'll try that. Thanks
89 User(s) are reading this topic (88 Guests and 0 Anonymous Users)
1 Members: Alden
- Lo-Fi Version Time is now: 29th July 2026 - 04:56 PM
