| burlybryan |
Jul 29 2026, 06:25 PM
Member ![]() ![]() Group: Members Posts: 162 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I've refurbished my trailing arms/bearing and the schnorr washers are pretty worn and I don't think they should be reused. Any reason I can't use common lock washers here?
| Superhawk996 |
Jul 29 2026, 06:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,971 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Any reason I can't use common lock washers here? Common split ring lock washers are less than useless for locking anything. Well documented by NASA and the entire automotive industry. https://ntrs.nasa.gov/api/citations/1990000...19900009424.pdf See page 9 & 10 There is no Schnorr washer involved at the trailing arm pivot & bushing. The OEM trailing arm pivot shaft itself has hardened serrations on the shaft ends. On the outside it is just a flat washer that goes beneath the OEM lock nut. If you’ve used the 914 rubber pivot shafts they used a star (toothed) lock washer instead of the OEM serrated shafts. Get another star washer if this is what you’re calling a Schnorr (which is yet another type of lock washer). With the 914 rubber shafts - you could substitute a Schnorr for the star washer but I would never substitute a split ring lock washer. |
| burlybryan |
Jul 29 2026, 07:00 PM
Sorry. I should have been more clear. This is for the 3 bolts that connect the trailing arm perch/mount at the body. I replaced the shafts with 914Rubber ones - and have the star washer, etc for those connections.
burlybryan schnorr washer question Jul 29 2026, 06:25 PM
Superhawk996 Ah, I think those 3 were originally split ring loc... Jul 29 2026, 07:20 PM
burlybryan
Ah, I think those 3 were originally split ring lo... Jul 29 2026, 07:23 PM
Superhawk996
Ah, I think those 3 were originally split ring l... Jul 29 2026, 07:29 PM
mepstein Correct, schnorr washers are one time only. Amazon... Jul 29 2026, 07:53 PM
worn
Correct, schnorr washers are one time only. Amazo... Jul 29 2026, 08:38 PM
URY914 https://www.amazon.com/s?k=schnorr+washers&...sl_8... Jul 29 2026, 08:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th July 2026 - 11:21 PM |
