| burlybryan |
Jul 29 2026, 06:25 PM
Member ![]() ![]() Group: Members Posts: 162 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None
I've refurbished my trailing arms/bearing and the schnorr washers are pretty worn and I don't think they should be reused. Any reason I can't use common lock washers here?
| Superhawk996 |
Jul 29 2026, 07:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,971 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Ah, I think those 3 were originally split ring lock washers on some early cars and later on were superseded by Schnorr. I’ve certainly disassembled cars with just a split ring washer there.
However, would stick with Schnorr’s. They will actually help prevent movement which a standard split ring lock washer will not. The Schnorr is a much better solution. |
burlybryan schnorr washer question Jul 29 2026, 06:25 PM
Superhawk996 Any reason I can't use common lock washers he... Jul 29 2026, 06:51 PM
burlybryan Sorry. I should have been more clear. This is fo... Jul 29 2026, 07:00 PM
burlybryan
Ah, I think those 3 were originally split ring lo... Jul 29 2026, 07:23 PM
Superhawk996
Ah, I think those 3 were originally split ring l... Jul 29 2026, 07:29 PM
mepstein Correct, schnorr washers are one time only. Amazon... Jul 29 2026, 07:53 PM
worn
Correct, schnorr washers are one time only. Amazo... Jul 29 2026, 08:38 PM
URY914 https://www.amazon.com/s?k=schnorr+washers&...sl_8... Jul 29 2026, 08:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th July 2026 - 11:21 PM |
