| slivel |
Aug 3 2026, 01:43 PM
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 553 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
Wife and I took the 914 to a cars and coffee (about 20 miles away) yesterday morning. Everything seemed normal except that we started noticing a strange odor on the way home. Just a few blocks from home the engine quit. I managed to get it running, although poorly and got it home. The first thing I checked was the battery. The case was bulging and too hot to handle. It was also outgassing vapor. This is a one-year-old AGM battery.
I got it exchanged for a new one at no cost to me but the experience was unnerving. I suppose that I now have to be certain that my charging system did not contribute to or cause this battery failure. Has anyone experienced this sort of battery failure? It must have been some internal short to have such a rapid decline. I really was concerned that the battery would rupture. The chemical vapors left a coating all over the engine compartment/trunk area. Are there any good ways to neutralize the acid residue? Thanks. |
| porschetub |
Aug 3 2026, 04:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,175 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I would suggest that the VR has failed and the battery has overcharged, the OP is lucky the battery didn't blow ,up appears it was close to it .
Not likely the battery was faulty so a full cleanup is required in the enginebay followed by a test to check input voltage @ the battery , don't proceed further if the voltage is over 14.4V (no load) . Don't continue using the car till you have tested otherwise you may have a repeat issue with a possible worse outcome ,good luck and report back, cheers. |
slivel Battery failure Aug 3 2026, 01:43 PM
NARP74 What battery? My experience with batteries over t... Aug 3 2026, 01:50 PM
rick 918-S There is likely a baking soda solution you could ... Aug 3 2026, 02:25 PM
slivel
There is likely a baking soda solution you could... Aug 3 2026, 04:07 PM
Root_Werks
I would suggest that the VR has failed and the ba... Aug 4 2026, 08:34 AM
brant Do you mind sharing the brand of battery? Aug 3 2026, 06:11 PM
slivel
It wa... Aug 4 2026, 10:09 AM
GregAmy Have you measured voltage when running? Aug 3 2026, 07:05 PM
slivel
Not yet... Aug 4 2026, 10:10 AM
porschetub
Not ye... Aug 5 2026, 01:37 PM
slivel
[quote name='slivel' post='3267522' date='Aug 5 2... Aug 6 2026, 09:51 AM
bkrantz Just a bit OT, but lately the only way I get decen... Aug 4 2026, 08:24 PM
dtmehall :agree: Aug 4 2026, 08:30 PM
Root_Werks Yup, anything that sits for more than a couple wee... Aug 5 2026, 08:21 AM
eric9144 There's a great old school speedo shop in Nort... Aug 6 2026, 04:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 07:38 AM |
