| NARP74 |
Aug 3 2026, 04:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,586 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
When I took my turn signal switch out to replace it, I had some wires that came out with it. Looks like the washer switch has been upgraded to an electrical type pump. The wires were unterminated. I need some small connectors to go though the steering housing so I can disconnect them the next time I have to replace either switch. The turn signal has already been replaced at least once, it did not have a stock one in it any more.
Should I just used small insulated spade lugs or is there a more elegant solution for two wire connections to go through the housing? |
| NARP74 |
Aug 3 2026, 08:19 PM
I'll have to figure out if one of those will fit through the opening in the column.
NARP74 Small Electrical Connectors Aug 3 2026, 04:11 PM
GregAmy I'm a big fan of using Deutsch connectors for ... Aug 3 2026, 04:24 PM
JeffBowlsby For your ‘74 car? It should have a plastic fema... Aug 3 2026, 10:42 PM
NARP74 This is for a window washer motor mod that someone... Aug 4 2026, 08:33 AM
NARP74 Kicked the can down the road for a little while. ... Aug 6 2026, 05:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 08:24 PM |
