> Small Electrical Connectors, Needed for Project
NARP74
post Aug 3 2026, 04:11 PM
When I took my turn signal switch out to replace it, I had some wires that came out with it. Looks like the washer switch has been upgraded to an electrical type pump. The wires were unterminated. I need some small connectors to go though the steering housing so I can disconnect them the next time I have to replace either switch. The turn signal has already been replaced at least once, it did not have a stock one in it any more.
Should I just used small insulated spade lugs or is there a more elegant solution for two wire connections to go through the housing?
JeffBowlsby
post Aug 3 2026, 10:42 PM
For your ‘74 car? It should have a plastic female multi pin connector housing on the main harness that mates with the window wiper switch.
- Lo-Fi Version Time is now: 22nd November 2026 - 08:24 PM
