> Battery failure
slivel
post Aug 3 2026, 01:43 PM
Old car....... older driver
Wife and I took the 914 to a cars and coffee (about 20 miles away) yesterday morning. Everything seemed normal except that we started noticing a strange odor on the way home. Just a few blocks from home the engine quit. I managed to get it running, although poorly and got it home. The first thing I checked was the battery. The case was bulging and too hot to handle. It was also outgassing vapor. This is a one-year-old AGM battery.
I got it exchanged for a new one at no cost to me but the experience was unnerving.
I suppose that I now have to be certain that my charging system did not contribute to or cause this battery failure.
Has anyone experienced this sort of battery failure? It must have been some internal short to have such a rapid decline. I really was concerned that the battery would rupture.
The chemical vapors left a coating all over the engine compartment/trunk area. Are there any good ways to neutralize the acid residue?
Thanks.
GregAmy
post Aug 3 2026, 07:05 PM
Have you measured voltage when running?
slivel
post Aug 4 2026, 10:10 AM
QUOTE(GregAmy @ Aug 3 2026, 06:05 PM) *
Not yet, but I will when I finish the cleanup.
porschetub
post Aug 5 2026, 01:37 PM
QUOTE(slivel @ Aug 5 2026, 04:10 AM) *
Good move not an easy task but you will get there ,cheers.
slivel
post Aug 6 2026, 09:51 AM
QUOTE(porschetub @ Aug 5 2026, 12:37 PM) *
Here is an update:
The cleanup is finished and I temporarily installed the new battery to see what I've got and begin troubleshooting. My engine is twin plug crank fired and uses Electromotive HPX modules. One of them is inop now and these units are no longer produced. Additionally, my tach is fried so there must have been some voltage spike that took out those devices.
Most probably my voltage regulator/alternator caused the problem. I don't know how a battery failing, even with an internal short could generate anything above the design voltage.
So now my immediate search is for a functioning Electromotive HPX that I can acquire. And an 8000 RPM tach. If anyone has either of these available, please contact me. Alternately, I will replace the entire ignition system. I want to stay crank-fired and twin plug. What are the options?
Last comment/question. Is it possible to pull the alternator on a 914/6 with the engine in the car? I do have an access hole in the firewall. Is there enough room to side the fan module forward to clear the engine shroud and then up and out?
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 25th August 2026 - 03:44 AM
